Question about Dell 926 All-In-One InkJet Printer
926 Printer not recognsing new cartridge
I have replaced the colour cartridge in my DELL Photo 926 All-In-One printer but it says that it is still missing? How can I fix this?
It was a faulty cartridge! Aparently DELL had a faulty batch from the Phillipines. Problem is now fixed. Thank you.
Posted on May 08, 2009
My DELL AIO photo 926 is telling me to remove tape from cartridges, how do I do that or how to solve this problem? i have new ink cartridges in already
remove the tape from the cartridges, it has tape on the contact point of the cartridge, pull them out again and double check dell printer
Dec 09, 2011 | Dell 926 All-In-One InkJet Printer
I can't get dell photo cartridge for 926 all-in-one inkjet printer to lock in its holder.
try pushing it? try to remember how you took out the old cartridge then reverse it dell printer
Nov 27, 2011 | Dell 926 All-In-One InkJet Printer
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
Follow the below instructions
  1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
  2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
  3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
  4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
  5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
  6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
  7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
Do you have a '926' or a '962' printer? You've cited each number in your problem description.
Remove the ink cartridge.
Reinsert the ink cartridge.
If the problem persists, contact Dell, and get them to replace it.
Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
All in one 926 cartridge problem
maybe you need to make sure it is set for color, click start then control panel then printers ,right click on dell photo ,click printing preferences, unclick printing in black and white , i hope this helps
Jul 22, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 ink cartridges holsters won't show up
Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
May 03, 2009 | Dell 926 All-In-One InkJet Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
210 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
