Question about Canon Pixma MX410 All-In-One Printer
My printer is saying close the feeder cover but the feeder cover is close. Also it is saying document is in adf
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Posted on Oct 29, 2010
puertobori
  • 7733 Answers
SOURCE: we have a canon pixma mx320 series printer. I
Try :
Posted on Oct 31, 2010
mace1mace
  • 1138 Answers
SOURCE: I have canon 320 MX,
Hi!
look more closely on the ADF section, if there is no paper remains then you must need to check if the paper feed sensor is not press down or stuck. This sensor, a small plastic latch slide is responsible for detecting load paper in the ADF section. Check if there is something that keeping it stuck in that position. You will need to open the cover of the ADF section to do this.
Hope it works.
Posted on Jan 04, 2011
SOURCE: Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Posted on Apr 15, 2011
  • 367 Answers
SOURCE: PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Posted on Aug 18, 2011
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Aug 23, 2010 | HP Office Equipment & Supplies
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Aug 31, 2009 | Konica Minolta PagePro 1390MF All-In-One...
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Canon Pixma MX410 All-In-One Printer Logo
20 people viewed this question
old marine
old marine
