Question about Epson AcuLaser C900 Printer
Printer error 6021
After changing transfer belt unit this error occurred
Error code in konica minolta c200 p 21
Relevant parts
Black PC drive main sensor (PS16)
Black PC drive sub sensor (PS18)
Main drive unit
Printer control board (PRCB)
Step Action
1 Perform the faulty sensor check procedure. *1
2 Check the sensor, for which a faulty condition has been checked, for installed position and
proper connector connection.
3 Wipe the sensor, for which a faulty condition has been checked, clean of dirt if any.
4 If P-12 persists, change the main drive unit.
5 Change PRCB.
Relevant parts
Transfer belt unit
PH unit
Step Action
1 Check the flat cable for proper connection and correct as necessary.
2 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
3 Change the image transfer belt unit if the transfer belt is damaged.
4 Change the PH unit.
5 Change PRCB.
Aug 21, 2014 | Office Equipment & Supplies
8650 machine error 21
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
Hope fully not the last two expensive.
Jun 04, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
A new installation is not detected when a new
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Xerox phaser6110MFP transfer belt error cant
Transfer Belt Error Aproblem has occurred transfer belt in the machine. Unplug the power cord and plug it back in.If the problem persists
Cleaning the inside of the sensor of the belt and then not change you change the blet assembly moz-screenshot-1.jpgmoz-screenshot.jpg
Apr 22, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Error Message SC471 for my Richo printer
Hi there the following is taken from the service manual hope this can help you.
471 Belt tension unit cam error
Even though the belt
tension unit tries to return to
its home position several
times, the home position
sensor is not activated.
• Defective transfer belt unit
• Pin 3 (CN25 on engine control board) unable to
send signal
• Defective transfer belt tension unit
1. Replace the transfer belt unit.
2. Replace the engine control board.
3. Replace the transfer belt tension unit.
Thanks J
Nov 18, 2007 | Ricoh Aficio CL2000N Laser Printer
Epson AcuLaser C900 Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
