Question about Electrolux Microwave Ovens
Microwave stops after 59 seconds
If I set the cooking timer to (say) three minutes, the microwave stops after every 59 seconds, and I have to press the start button to resume the cooking timer. It then stops again after a further 59 seconds and so on until the cooking time has completed.
  • 998 Answers
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Posted on Nov 25, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: R957 cooks for 59 seconds
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1870 stops at 59 seconds
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 29, 2009
SOURCE: when timer set to cook for any time over one
I have exactly the same problem; always after 59 secs, it stops.
Posted on Aug 30, 2010
ZJLimited
  • 17970 Answers
SOURCE: I Have a sharp microwave
That would be a problem in the damper assembly, either a bad switch or motor, or the damper door is jammed or blocked. Consult the attached diagram for general reference. The damper switch is the same as the primary interlock (door) switch.
Its location varies by model, but you'll have to take the outer cover off to find it.
The best place to order Sharp parts is Tritronics or you can call them toll-free at 866-779-5835.
If you only need a switch, you can order a universal type HERE
Also, I quote other similar solution...
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Good luck.
Posted on Mar 07, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: My Sharp R-975 Microwave after settin the timer
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
See the attached sample drawing for a typical damper assembly.
I'm not sure this is a US model or if parts are still available, so look up Sharp in your country.
Posted on Mar 13, 2011
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
My Sharp R-975 Microwave after settin the timer and starting only runs for 59 seconds and stops, I can press start again and it goes for another 59 seconds
Mar 13, 2011 | Sharp Microwave Ovens
Sharp model R-1871 shuts off every 59 seconds
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 30, 2009 | Sharp R-1871 Convection Microwave Oven
Sharp Microwave oven R-96STM Problem started after powercut. Whatever duration timer is set for, power always stops after 59secends. After pressing START button again, oven runs for a further...
Info on ordering Sharp UK parts / spares is here.
Sep 07, 2008 | Sharp Microwave Ovens
Help please
Are you saying that it will stop cooking after 59 seconds, but it will resume cooking if you press Start again?
(If not, please reply back and clarify)
If so, this is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Aug 04, 2008 | Microwave Ovens
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
Jul 31, 2008 | Microwave Ovens
Sharp mdl R-1870 convection microwave runs for 1 min
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 08, 2008 | Sharp R-963 Convection/Microwave Oven
Microwave Ovens Logo
309 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
