Question about Refrigerators
GE Profile Artica Side by Side Refridgerator isn't cooling.
Both the freezer and the refridgerator are not cooling. Unit is approximately 7 years old. Fan seems to be working. Power is to the unit.
  • 2 more comments
  • angelahasse May 08, 2009
    No frost on the back of the freezer. I think it stopped working over 24 hours ago. I can hear it humming like normal.
  • Victor
    Victor May 11, 2010
    Hi, Check the rear panel in the freezer section to see if there is a frost build up. If so, there is a defrosting problem. I can help further is this is the case.
    Vic
  • Mark Nichols May 11, 2010
    well you have to take the back off the freezer and see if there is any or no frost on the coils
    frost on the back of the freezer? you can hear the compressor and fans? if you take the back off of freezer do you see any frost on the coils? if just a little bit half way acrossed the coils indicates insufficent compressor or low on freon. if you have alot of frost indicates a defrost problem
  • 400 Answers
You say fan seems to be working? it either is or it is not working. If you are getting a reduced airflow in the cabinet, it may indicate that the evaporator coil is iced up and needs to be manually defrosted.
Posted on May 08, 2009
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
GE refridgerator won't cool
First of all check and see if the compressor is running and if not is it very hot to the touch. If the compressor is not running but hot then the compressor is either locked up or is cycling on its internal thermal overload. If this is the case then either the condenser fan motor is not running and/or the condenser coil is very dirty. If the condenser coil is dirty you need to blow it out with compressed air(watch out for all the blowing dust). If the compressor has been cycling alot on its internal thermal it will eventually lock up permanently and you will need a new compressor. I hope I was of some assistance to you!
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Ge profile artica refrigerator/freezer won't turn on error code 888
The refridgerator was in showroom mode. I just unplugged it and plugged it back in, to correct the problem.
Jun 27, 2008 | GE Refrigerators
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
226 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
