Question about Xerox Phaser 8560DN Laser Printer
How can i reset admin password on xerox 8560dn
  • 47 Answers
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  3. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  4. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  6. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Posted on Dec 08, 2013
SOURCE: how to reset a forgotten
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
Posted on Oct 18, 2008
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
SOURCE: Default admin password for Xerox Phaser 8550DX
Default admin password is 1111
Posted on May 03, 2010
SOURCE: How do I perform a factory reset on a Xerox device
lol m looking for the same thing if u have found the answer can you please post it here ?
Posted on Jul 21, 2010
Hello guys..please help me my printer xerox workcentre 7232 and i forgot my administrator password,how to recover my password or how to open it,tnx
you have to go into service mode to reset admin password
1) go to copy and hold zero for 7seconds and hit start while holding
2)password input which is 6789 ok now ur in tech mode
3)go to settings security change admin password
Aug 08, 2017 | Xerox Office Equipment & Supplies
Xerox Phaser 8560DN error code 07,010,43
Sadly, Xerox says that this means "Power off the printer and contact support". Phaser 8560 Support Drivers
However, there is something about "opening the pivot plate", it's Greek to me, but google it and see if you can't reset the brain in the printer and get it back to life without an expensive service call.
Aug 23, 2014 | Xerox Phaser 8560DN Laser Printer
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
09,008,43:167 error on an Xerox 8560dn
The error code 09,008,43 indicates the ink is not melting into the printhead. Raise the ink loader Top Cover to access the ink blocks and make sure they slide down properly. If this doesn't fix it you gonna have to call Xerox for service maintenance.
Nov 18, 2010 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560dn says it is out of Cyan ink, but it is not.
The inksticks are probably jammed in the slot. If you're using non-Xerox ink, an error reset is required. Since the non-Xerox ink sticks are not the right shape (since the shape is a registered trademark), they don't always trip the sensors when they come down the chute.
Jun 05, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Jun 03, 2009 | Xerox Phaser 8560DN Laser Printer
May 02, 2009 | Xerox Office Equipment & Supplies
Centreware password on Xerox 7335
On mine it was the other way around username 11111 & Password x-admin
Jan 21, 2009 | Xerox DocuPrint 4517 Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
