Question about Dryers
Hi I have a whirlpool AWZ8477 condenser dryer, it's plugged in, the fuse is ok but there's no power to the control panel....any thoughts??
    Scholar:
    New Friend:
  • 81 Answers
Try plugging a lamp into the outlet to see if you have power to it. If you do, you do, you probably have a bad mainboard.
Posted on Nov 27, 2013
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
Posted on Aug 15, 2008
larryyb
  • 291 Answers
SOURCE: Whirlpool Dryer GEW9250PW0
the control panel is bad / it is also called a user interface
Posted on Nov 25, 2008
aasc
  • 1606 Answers
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Posted on Jul 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: My whirlpool dryer won't start.
Check your door switch for continuity. If no continuity,replace it.
Posted on Aug 13, 2009
Ranglo
  • 1194 Answers
SOURCE: My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Posted on Jan 01, 2011
Where is cut off switch on whirlpool condenser dryer
Typically on condenser styles there is a hi limit thermostat on the element housing.
Feb 01, 2015 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    It will power on but will not tumble it will not go off of sensing i have checked the belt it is ok and i have tried resetting our home fuses help plz
    Hi
    I believe the control is fine rather it is the thermal fuse located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if there is no continuity then replace it as it cannot be reset. Hope this helps...please post back for further assistance.
    Daniel
    Feb 13, 2011 | Whirlpool WED6400S Electric Dryer
    No power to Whirlpool Condenser Dryer AWZ7813
    check your wall plug it could have went out
    Jan 29, 2010 | Dryers
    Whirlpool dyer will not work, have replaced the board but
    Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
    Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
    No power to selector panel
    Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
    Jul 14, 2009 | Whirlpool Dryers
    Whirpool GGw9250Pw3 no power on Control Panel Inside light works
    In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
    Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
    Dryer will not start
    Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
    Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    59 people viewed this question
    Top Dryers Experts
