Question about Konica Minolta bizhub Office Equipment & Supplies
What does the hourglass symbol mean - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Just a time thing does not mean anything means machine is getting itself ready
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 25, 2018
2 Suggested Answers
kyuaus
  • 14 Answers
SOURCE: What does The Hourglass symbol mean on a Samsung front load washer
The hourglass symbol usually means the machine is "Delayed" This might be because of a breakage or issue inside the machine. If this is not the case, check the user instruction manual
Posted on Oct 03, 2016
Oct 03, 2016 | Samsung Washing Machines
I have an HP PSC 2510 that has a permanent hourglass busy symbol showing. When turned off and on there is a grinding noise from the scanner transport mechanism which ceases after about 1 minute but the...
Looks like a faulty gear mechanism in your scanner. It is not able to return to the home position. You could try a hard reset: Unplug from power source and PC, wait about 5 minutes and try again. If the issue recurs, then you will need to take it in for servicing..
Jul 04, 2008 | Office Equipment & Supplies
I plugged in into my computer and just has an hourglass symbol on it
hi, an hourglass symbol indicates that it is loading or your computer is trying to access the unit. Hope this helps. goodluck
Jun 23, 2010 | Audio Players & Recorders
I think the internal battery has gone??? cannot see through viewfinder- which has a flashing sybol
If your "timer" symbol is like a clock-face, then it's telling you that the date/time need to be reset.
If it's an hourglass symbol, then check that the mode selector is not set to "playback"
Dec 08, 2009 | Nikon Coolpix 5700 Digital Camera
Frozen hourglass symbol on mp4 screen
If you are using Mac, you must use USB to connect to connect to itunes. If you are using Windows you MUST use Firewire. I don't know why this is but each system won't recognize the other's connection medium. Make sure you are using the correct cable. If my wire connection doesn't work then it is reversed. Try it the other way around. The only other thing I could think of is that you are trying to upload an MP4 that the system doesn't recognize. try a format converter if this is the problem, they can either be demoed or bought four 20 bucks or so.
Mar 21, 2009 | Apple iPod touch
Bellum fight drawing the hourglass
It needs to be figure 8 you draw, don't draw it back wards (lot's of us do!) so try starting at a different point. Also it does not have to be huge - just think of writing the number 8 as answer to a math question on the DS. Just keep trying different ways, I sometimes had this problem with the Frog symbols, it's just a matter of triggering the right spots in the touchscreen.
Your game is not faulty.
Nov 17, 2008 | Nintendo The Legend of Zelda: Phantom...
Constant hourglass symbol-draining battery
Hi, this is called the hourglass of death, the device is stuck in a reboot cycle.
You will need to reload the applications, but you can't use Desktop manager because the device resets and the connection drops.
First make sure the BB is unplugged, then go to Program Files > Common Files >Research In Motion > AppLoader and run loader.exe. Click next, it will say port : COM PORT 1 now is the tricky part you have to plug in the BB and COM 1 will change to PIN: UNKOWN , when this happens you have to quickly click next before it reboots again, then it will ask for pin and now has an connection with the device so you can go ahead and re load all the apps.
Good Luck
Apr 16, 2008 | RIM BlackBerry 7250
Hourglass symbol
dear lund0448
there might be some hardware problem or may be obstruction in the way of the print cartridge carrier.better check it yourself by opening the printer or you send it for servicing.
Feb 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Legend of Zelda - Phantom hourglass
<img src="http://www.1up.com/flat/MyCheats/Zelda%20Hourglass/1_2re/zelda041.jpg" img>
draw an hourglass shape (like a figure-8 with a flat top and bottom) that starts from the top left corner (1), across (2), diagonally down to the left (3), across the bottom (4) and back up to connect with the starting point (1). If done correctly, the hourglass shape on the door will glow and let you through
Jan 12, 2008 | Nintendo Game Boy Advance Console
167 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
