Question about Carrier Heating & Cooling
Fan motor replacement carrier
The fan motor on my condensor unit died. Replacement (Dayton 4m261J) motor has different wires than original (GE P612S). I got a capacitor to match the new motor, has two terminals vice three on the existing capacitor. I don't know how to connect the new motor.
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
meBNme
  • 334 Answers
SOURCE: I have a Trane XE1200
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
  • 674 Answers
SOURCE: unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Posted on Jun 09, 2010
Testimonial: "Thank you very much for your help-I had the motor leads reversed and when I placed the brn/white to the common on cap like someone else had instructed it of course shunted out and blew the fuses in the disconnect. I used my meter(duh) and switched the motor leads. We got air!! THANK YOU!"
heatman101
  • 43501 Answers
SOURCE: Original AC Condenser fan motor had three wires L1
Yes, that can be confusing...hook the tan wire with the white strip onto the same line wire as the one going to the capacitor...usually the L2 wire....so then in reality you have the two tan wires hooked onto the common and the F terminals of the cap...
heatman101
Posted on Aug 16, 2010
  • 674 Answers
SOURCE: I bought a replacement Dayton electric condenser
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Replaced a ge condensor fan 3 wire with new dayton the wires are different...old fan has a wire connectort mouted to it orange,black yellow, the new one 2brown 1 with white stripe, purple, black, i have...
the new ge fan requires its own capacitor, the brown and the brown/white go direct to new fan capacitor. black to relay (leg one of power) purple to relay (leg two of power. the compressor will have a wire to the relay and the other to the herm terminal. you now will have nothing to the original capacitor fan terminal.
The new motor will have the diagram showing this. you need the capacitor that goes with the new motor. the grainger guy should have sold that to you with the motor.
Apr 11, 2013 | Heating & Cooling
I have a carrier roof top unit that goes off on short cycles. how should i trouble shoot
It could be Low on Freon and going OFF on low pressure switch.......
Or it could be a dirty condensor coil or a Condensor Fan Motor not running and going OFF on High pressure switch....
Or if you are running the RTU in Low Ambient Conditions like 50* to 60* degrees Outside the Condensor Fan Motors could be cycling on a Fan Cycling Control....which is normal operation
So it could be any one of these or something different I would need to know what you are talking
about what is cycling??? Fan, Compressor , blower motor, whole unit shuting down, etc.
May 14, 2011 | Heating & Cooling
I bought a replacement Dayton electric condenser fan motor. The original GE had 3 wires. L1 L2 & the fan capacitor wire. The Dayton replacement model 4MB21 has 4 wires, L1 L2 and 2 capacitor wires tan...
Aug 16, 2010 | GE Heating & Cooling
Original AC Condenser fan motor had three wires L1 L2 & Fan Capacitor The replacement Dayton motor has 4 wires, L1 L2 & 2 capacitor wires solid tan and tan with white tracer One goes to the F...
heatman101
Aug 15, 2010 | GE Heating & Cooling
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
Sep 07, 2009 | Heating & Cooling
AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
