Technika 22-700 standby light flashing
Pretty sure the reason for my Technika 22-700 standy light is flashing is due to a blown diode and/or resister, reading http://www.normsweb.com/tektips/technika.shtml it says to replace diode D102 and resistor R110 but this guide does not match up with my model of Technika TV, tried searching web but can not find any links to my model of Technika ????
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 25, 2013
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
SOURCE: Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Posted on Jan 07, 2010
SOURCE: technika lcd 19dvdid-207 won't turn on. flashing red light
Try D103, usualy goes S/C!
Posted on Jun 09, 2010
Warf135
  • 137 Answers
SOURCE: Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
Posted on Feb 23, 2011
SuperTech-11
  • 1591 Answers
SOURCE: i have a technika lcd tv model:lcd191d-107/207
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
utube.png You-Tube video "8l0AUj8QUkg&NR=1&feature=fvwp" placeholder
utube.png You-Tube video "Y7b_nTaZYcU&feature=related" placeholder
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 10, 2011
Why can't i turn on my dvd with the remote control its a technika 22-212i
Please make sure your remote control is working properly.
It is pretty common for remote control buttons to stop working after a certain time period or due to excessive usage.
Feb 04, 2012 | Televison & Video
May 18, 2010 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
I have a technika lcd tv/dvd. It is only a few months old but it is stuck in standby with the red light on the front continually flashing and will do nothing else. Any ideas?
I have same unit (which works in my case) but the red light does not flash on 'Standby', only when it is seeking a station after pressing the red button on the remote.
Nov 16, 2009 | Televison & Video
Sep 01, 2009 | Televison & Video
Jul 09, 2009 | Televison & Video
Technika TV LCD26-207 died in service
I know the cause of the fault is R983 - it appears to be a pullup resistor that kickstars the PSU. If you look you will find its slightly burnt. I dont know the value of this resistor. But if you connect a 60w mains lamp in place of the resistor the standby light will light then can start the set by pressing one of the buttons on the side of the set. If anybody knows the value please let us know. The part will only be pennies. Keith
Oct 11, 2008 | Televison & Video
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
494 people viewed this question
Top Televison & Video Experts
