Question about Bosch Dishwashers
Upper spray arm came off of SHU9952Uc/22. How do I put back on?
  • slinsky May 08, 2009
    how do i reattach upper spray arm to dishrack, please describe.
    sorry, Bosch model SHU9952 uC/22
  • 190 Answers
Dear slinsky,                    Can you please mention the maker's name? you have only mentioned the model number here..
Posted on May 08, 2009
  • 2 more comments
  • Ajith Kumar May 08, 2009
    Hi. the plastic ring on your spray arm is worn. you should replace it with a new one and the problem will be fixed.
    i also recommend you to go throught this link for details http://www.partselect.com/repair.aspx?ap...
    You have to unscrew the piece that the arm attaches to and put it back together and reattach.Try this before replacing ring. If this doesnt work then replacing ring is the way to go.
    Please rate my solution if i've satisfied you. Thank you.
  • 3,230 Answers
The upper spray arm assembly snaps onto the upper dishrack.
If one or more tabs are broken off then the upper spray arm assembly has to be replaced.
- The part number for the upper spray arm assembly is AP2802458
Good Luck!!
Thanks for using FixYa.
Upper arm spray fell off my Indesit dishwasher. How do I put it back on?
Usually, there is a small stainless steel sc rew with a knurled edge. It fixes through the central boss of the spray bar. You should find it in the bottom of the machine in the strainer, or hiding in the bottom somewhere.
Jun 09, 2016 | Indesit Dishwashers
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
Dishes are not getting clean. Dishwasher does not take off the smallest speck of food. Hot water works. Cycles sound the same
There could be a couple of things that might be affecting the cleaning ability of your dishwasher.
First,there is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My children used to put large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, it could be that the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Aug 14, 2011 | Frigidaire 24 in. PLD2850 Built-in...
Top spray arm does not spin
The upper spray arm is powered by water from a tube that runs up the back of your machine on the inside. If the connection is not aligned, then the water can't get to the spray arm. My children use to knock mine out of kilter when they loaded the lower section. It's easy to see if the supports are not attached to the upper rack and a simple snap will get them back in place.
It may also be that the spray arm jets are clogged.Depending on the model, the upper spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then remove the arm. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure..
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | KitchenAid Dishwashers
Dishes do not come clean
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
Jul 04, 2011 | Maytag Dishwasher
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
Upper spray arm not working ge quiet power 22 yrs
Often they will not spin because there is stuff inside that plug the holes...
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 17, 2010 | Dishwashers
Water not pumping to upper spray arm
First,
See this link for a picture of the upper spray arm and manifold assembly.
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=KUDP02IRBL0&model_id=163723&diagram_id=380403
Referring to parts 1, 6, and 9, make sure everything is attached, secure, and lines up when the upper rack is pushed back into place.
It's possible the pump is obstructed and not delivering water to the upper arm, but the more likely cause is a displaced upper arm feeder tube. If no luck, start checking for obstructions in the feeder tube, manifold and the spray arm.
Mar 14, 2010 | KitchenAid 24 in. KUDP02IR Dishwasher
The upper spray arm came off. How to I put it back on?
I realize this problem was in March of 2008 but if in the case someone else needs the solution. The Frigidaire website doesn't list this in there troubleshooting list either.
I had the same problem and let the upper spray arm off for a couple of months. My glasses were not getting cleaned as well so I was rewashing everything by hand. What's the point of that if I have a dishwasher.
On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
From now on be careful what you place on the top rack, if the item is too big it will cause it to snap off again. I know I will :)
Thank god I didn't get a repair man in here for something as minimal as that.
Mar 29, 2008 | Frigidaire 24 in. PLD2850 Built-in...
I have the DA4142 and if its anything like mine, the upper spray arm simply clips into place under the upper tray rack.
Jun 23, 2006 | Zanussi 18 in. DA4342 Free-standing...
Dishwashers Logo
134 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
