Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Wiring diagram for sakura s200
Indicators and back light not working
Where can I buy spare light bulbs for my Sakura scooter type bike
Hi, Hendrik any motorcycle/scooter shop will have spare bulbs or check with Amazon.com for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Electric Scooter and Bicycle Troubleshooting Guide
Sakura scooter thing
Question Answer
Jun 04, 2016 | Motorcycles
Right blinker not working 1999 Buick park avenue
You'll need to find a wiring diagram an component location chart to check this out . Here is a diagnostic flow chart for trouble shooting this problem ! Do you know how to use a voltmeter ?
DEFINITION: This table diagnoses inoperative turn signals on one side. It assumes that the cornering lamps, hazard lamps, and turn signals on the other side all operate properly.
Did you perform the Exterior Lights System Check?
Go to Step 2 - yes
Go to Exterior Lights System Check - no
  1. Disconnect the turn signal flasher connector.
  2. Turn the ignition switch to the RUN position.
  3. Place the turn signal switch in the appropriate position.
  4. Connect a DMM from the appropriate turn signal flasher connector cavity to ground:
LH: cavity C (ORN)
RH: cavity B (BLK)
Is the voltage within the specified range?
10-15 V
Go to Step 3 yes
Go to Step 5 no
Connect a fused jumper between the appropriate turn signal flasher connector cavities:
LH: cavity C (ORN) to cavity D (YEL)
RH: cavity B (BLK) to cavity F (TAN)
Do the appropriate turn lamps light without flashing?
Go to Step 4 yes
Go to Step 6 no
Replace the turn signal flasher. Refer to Hazard and Turn Signal Flasher Replacement .
Is the repair complete?
5
Repair the open in the appropriate circuit:
LH: CKT 57 (ORN) between S200 and the turn signal flasher
RH: CKT 58 (BLK) between S201 and the turn signal flasher
Refer to Wiring Repairs in Wiring Systems.
6
Repair the open in the appropriate circuit between the turn signal flasher and the IP fuse block:
LH: CKT 685 (YEL)
RH: CKT 686 (TAN)
May 09, 2015 | 1999 Buick Park Avenue Ultra
What amp fuse do I need for a Sakura s200?
It will be in the manual or see a dealer.
Apr 20, 2015 | Electric Cycling
Sekura electric bike I have power to lights and indicators but the bike wont drive.?
I am not familiar with Sakura, but if it is fitted with e-brakes then you could try disconnecting one then the other to see if it now works. If it does then your ebrake is faulty & you need to replace the brake sensor in the e-brake or the complete e-brake lever.
May 11, 2014 | Electric Bicycle Motor, Bike,electric...
I have a sakura s200 electric bike can i make it any faster ?
Change out the gears with a higher ratio that turns the wheels faster for the same motor RPM. Another method is find a motor that has a higher rpm capability.
Aug 23, 2012 | Electric Bicycle Motor, Bike,electric...
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
I have Sakura kitchen range hood model #c R706, R727 and Want to know how ro chaneg teh bulb. Thanks
I found all the part I needed for my Sakura range hood at http://www.rangehoodking.com/ they had everything I needed. of cos that light bulb too!
Dec 31, 2010 | Kitchen Ranges
Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
Jun 12, 2009 | Maytag MEC5430 Electric Cooktop
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
54 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
