Question about Tivax Michley Mitraveler 10-inch Android Tablet
My tablet says usb storage removed, insert new media. how do I return the usb storage?
How do I add additional memory to my Samsung SM-T710 reader? What little I can find tells me I can add up to 128 GB with an optional MicroSD card.
MAKE SURE YOU TURN OFF YOUR TABLET before adding MicroSD card storage.
Your Samsung SM-T710 Galaxy Tab has a place for a MicroSD card on the lower edge of the unit below the volume button.
You will see a small hole. If there was no 'tool' included with your tablet, you can use the end of a paper clip bent out to create a small stiff wire you can use to insert into the hole.
Once you insert the tool/paper clip into the hole, the tray which is used to hold the MicroSD card will pop open.
When you have purchased your MicroSD card, you can insert it into the tray (it is 'keyed' to only fit one way in the tray). Then push the tray fully back into the slot, and your new storage should be ready to use.
Once you turn on your tablet, the tablet should recognize that you have new storage. It may ask you to 'format' the card.
You should explore options in your Settings to have your tablet use the new storage as the default destination to store music, pictures or videos. And it may allow you to install new programs to the SD card, saving space on your tablet's internal storage for the operating system.
Dec 15, 2016 | Samsung Electronics - Others
My grandpa bought a RCA for me to put all his songs on it. And they are all on the computer and i dont know how to transfer them
There are two ways:
  • From computer. Use micro USB cable,connect it to tablet. Computer will detect the tablet as storage device. Open explorer. Copy your files from computer to tablet in the folder where you want to store/save.
  • Use micro SD card. Insert microSD card to computer/laptop. Copy your files to microSD card. Remove microSD card. Insert it on your tablet. Access the files. To access files on microSD card, you can see on this video :
Video is courtessy of Youtube - RCA.
You also can use flashdisk as a files transfer storage.
If using flashdisk,transfer procedur is same as for microSD.
If using flashdisk,you need miniUSB to USB adapter. See photo:25848604-tr0bbbe1g5ua2mps4ks3loyz-2-3.jpg
I hope this help.
Regards.
Sep 03, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I turn on usb storage when attaching to my computer
Connect your tablet to the PC via the USB connection
After a few seconds, during which the two computers are negotiating the connection, a small USB icon will appear in the toolbar at the lower right, near the clock
Touch the toolbar clock and in the pop-up menu that will then show, touch the "Turn on USB storage" entry.
In the window that then opens, touch the "Turn On USB Storage" button that appears near the bottom of the frame
You now have files access to and from the PC, and can up and download files to eiher the micro USB card (if fitted) and/or the internal storage memory. [:o)
Sep 14, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Windows xp does not recognize my ematic 8 pro series tablet. Do i need drivers?
Hello
What version of Windows XP are you running? Your best bet is to have Windows XP Service Pack 3.
The issue is that the tablet will appear in Windows as a "storage device". The problem is that Windows XP will likely require a driver to understand that your tablet is a memory storage device.
It appears you have two options:
1. upgrade to Windows XP Service Pack 3, reboot the computer and then connect the tablet and see if the OS can recognize your device
2. remove the SD memory card from the tablet and, using a SD card reader on your PC (which you may need to purchase), insert the SD card into the card reader and use this method to transfer the files to the card. Return the card to your tablet.
It appears that Windows Vista, 7 and 8 will recognize your tablet automatically.
Nov 09, 2013 | Ematic EM718VIDHD (8 GB) Digital Media...
How do you update
Before we begin you will need to have the following ready. ? The Coby Kyros with a battery level of 30% or more, the USB cable and an empty micro SD card with a minimum of 4G. The Micro SD card should be inserted into the Kyros. Start by going to our website www.cobyusa.com to download the zip file to your computer. The file can be found on the main page for the MID7015. It is titled "UPDATE.ZIP". It is important that you do not UNZIP the file.
Once file has been downloaded to your computer, turn the Kyros on and connect the unit to the computer via the included USB cable. At the top of the main page Go to the navigation bar and scroll down. A menu will open with several USB notifications.
Click on the External USB connection. This connection refers to the inserted SD card. A new menu will appear Click on MOUNT. Once complete your computer should recognize the Kyros device. A screen will open and show the Removable Storage drive. If this window does not open, please go to the start menu of your computer and select computer or my computer. There may be several drives shown. Please choose the one that corresponds to the SD card, it should show as empty. Open the drive. Now you may drag and drop the ZIP file into the removable storage drive. This process will take approximately 1 minute to complete.
When complete Go back to the Main Screen of the Coby Kyros Once again go to the top navigation bar and Turn off the USB Storage. Another window will appear with a turn off message. Make sure to click on this as well. Disconnect the Coby Kyros from the USB cord attached to the computer. Then Press the Power button, it will again prompt you to power off from the main screen twice.
Wait 5 seconds. During this time locate the power button and the return button. Press both buttons at the same time. Continue to hold the buttons down until you see the warning triangle and android logo. Once the symbols appear you may release.
Press the return button again. The reboot section will appear. You will use the Home and Menu keys to scroll through this section. The Home key scrolls up and the Menu key scrolls down.
Scroll down to Wipe data/factory reset. Press the return button to select. Scroll down to Yes and hit return. The Kyros will notate the Data wipe is complete.
Scroll down to Apply SDcard and press return The Kyros will notate Install from SD card complete. This will take approximately 1 minute .Select Reboot system now and hit return key
Congratulations you have just updated your Coby Kyros
For more info visit www.cobyusa.com
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Coby Kyros 716829701508 Tablet PC
I have down loaded and installed the driver but still when i plug my phone into computer its not there. If i choose media player it does not show up in Windows media player. if I choose Mass Storage it...
Well, when you connect as mass storage, there is an usb icon on status bar on your phone. Select it and there will be written something like Select to turn on/off usb connection. Once you turn it on, you will get a prompt on your computer as it will see your phone storage card as mass storage.
Aug 02, 2011 | Samsung Galaxy S GTI9000 Smartphone
Every time its gets to 62% is says an error with (8002F997) ive tired the method by swiching the media sever to disable but that didnt work. what eles do i do
Error code "8002F997" means your PS3 is having issues updating your system software directly via internet. As a workaround you'll use external storage media, such as a USB thumb drive, to transfer the software to your PS3
1. Requirements
- A USB cable (not necessary if using a USB thumb drive)
- A PC with Internet access
- Storage media or a USB Mass Storage device such as a USB flash drive
2. Downloading and saving the software
- Plug in your USB drive to your computer, and create a folder on the storage media in which to save the update data. Create a folder named "PS3" on the storage media/USB device. Within the PS3 folder, create a folder named "UPDATE".
- Download the update data from
http://dus01.ps3.update.playstation.net/update/ps3/image/us/2011_0310_91ee193a2fa921a6fce780fc40236e3b/PS3UPDAT.PUP
and save it in the "UPDATE" folder.
Note:
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3 will not recognize the update data. The folder name must be in all uppercase letters.
-> Location: Save in the "PS3" folder > "UPDATE" folder
-> File name: Save as file name "PS3UPDAT.PUP".
3. Updating the PS3 software
Note:
Do not turn off the PS3, or remove the USB drive, during the software update!
- Insert the USB drive/storage media into the PS3
- On your PS3, from Home Menu (second icon from the left) -> System Update ->Select [Update via Storage Media].
The system automatically searches for and finds the update data saved on the storage media or USB device.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
How do you connect storage media
Storage Media is just an USB stick or any type of memory stick (xd card, sd card, cf card, even micro sd is considered 'storage media') If you are trying to update and it is asking you to insert the firware with the storage media, you will have to put the files on a usb stick or any type of storage media and then insert the card in either the memory card slots (if you have a original 60/80g launch model), or use a memory card reader.
I hope you understand. Please post a new question if you need further assistance or click chat on my page.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
I can not figure out how to open the reader to insert the disk.
According to what I was able to find the device does not require to be opened to insert the storage media.
I am assuming the device you are referring to is the same as the device shown in this link: http://www.dynexproducts.com/pc-314-2-dynex-5-in-1-usb-20-card-reader.aspx
If you are having troubles getting your storage media to fit into the slot then it is possible that the media type is unsupported by the device or that the storage media is being inserted incorrectly.
I hope this solves your problem, best of luck.
Jul 08, 2009 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Pes2008
That's the best way to do over your PC to your USB. Create a folder on the storage media in which to save the update data.
Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  • Download the update data and save it in the UPDATE folder created in step 1. Select here to start the download.
Notice
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data.
  • File name: Save as file name “PS3UPDAT.PUP”.
    Update procedure
Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select (Settings) > (System Update), and then press the button
    Update procedure
Notices
  2. From the home menu, select (Settings) > (System Update), and then press the button.
  3. Select [Update via Storage Media], and then press the button.
  4. Start the update data.
    Press the button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to (Settings) > (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
You can delete the update data from the storage media or USB device after the update has been successfully completed.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Tivax Michley Mitraveler 10-inch Android Tablet Logo
319 people viewed this question
Top Tivax Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tivax Audio Player and Recorder Expert? Answer questions, earn points and help others
