Question about Whirlpool Refrigerators
Model #G16FARXXY has a bottom freezer. When I open the freezer door, I can see that the base of the freezer is full or ice. Abouit once a week, water flows out of the bottom of the freezer.
SOURCE: water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Posted on Nov 12, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
The door on the bottom of my freezer will not pull open. Ice has been building up in the bottom for some time. We were away for 1 week and now it will not open. I have shut off the freezer for more than...
If it is ice holding the door closed, you might use a hair dryer and a putty knife. Heat the blade of the putty knife with the dryer and work your way around the seal. If that doesn't work, then you probably have an ice buildup on the rails and will have to defrost the unit - Hope the freezer isn't full of food! You can hurry the defrost up some by using the hair dryer blowing down the fan exhaust hole.
When you finally get everything open, you should check the condition of the door seals, make sure the evaporator fan is operating (if circulated the cold air up and also remose the humidity from the freezer).
Aug 06, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Maytag Bottom Freezer not working
Maybe fan in freezer not running to circulate air.
Aug 28, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Lg, french door, bottom freezer ice maker doesn't make ice. Lights are on but no ice action.
It is possible that your ice maker has gone out. Can you tellme how old yiur refrigerator is? Normally , they can go out after abouit 18 monthw depending on different instances.
We will be happy to help get you going agin. If you would like for us to continue to assist you, you can contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We are at your service and look forward to working with you.
Nov 07, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Model sku fu25w 24.7 cu. ft. freezes water
I have a Woos's frost free freezer and it keeps getting ice in the bottom what can I do to stop this?
Dec 29, 2008 | Woods Upright Freezer MU07W
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Refrigerators Logo
232 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
