Question about Dremel Plunge Router Attachment 335
Silverline collet loose - Dremel Plunge Router Attachment 335
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
I have problem with my collet in my router. As soon as I tread the nut on the collet squeezes to the point I can't get a bit in. If I put the bit in the collet then try to tread the nut on it will not...
Never tighten a router collet empty. This will bend the collet smaller and it will be too tight.
Simply replace the collet. Call the Mfg the collet may be off specs a few thousands of an inch.
When not using the router store the nut loose on the threads enough it doesnt fall off.
Feb 19, 2011 | Freud FT2000E 3 Router
How do you use a frankford arsenal bullet puller
Remove the screw on cap and select the appropriate collet.
Place collet over hole in top of Impact Bullet Puller and screw cap on loosely.
Insert cartridge with a rotary motion until case rim seats against the collet, or the extractor groove engages the collet.
Tighten cap firmly.
Strike the Impact Bullet Puller against a hard wood surface, while holding the Impact Bullet Puller handle parallel to the surface and the Impact Bullet Puller head perpendicular to the surface at the time of impact.
This technique will give the maximum inertia to the bullet being pulled. Two or
three impacts should pull most bullets.
Never hit the Impact Bullet Puller on a steel or concrete surface. The best hard
surface to use is the "end grain" of a block of wood.
Check tightness of cap after each blow.
Remove cap, push case out of collet, and recover pulled bullet and powder
Feb 15, 2010 | Arsenal Gaming Frankford Arsenal Micro...
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
The router bits will not fit in the collet. When the collet snaps into the collet nut the bit does not fit.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 15, 2009 | Freud FT2000E 3 Router
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
I am unable to get a tight fit on my router bit.
could be a couple things. First how is the shank on the bit e.g. is it worn down, second is it the right size for the collet being used (have to ask) and what is the condition of the collet and collet nut. What I would do is make sure there is nothing to prevent from completely tightening the collet nut. Also make sure if the collet locks into the nut that it is properly installed. Lastly make sure that you use the wrenches provided to tighten the assembly. If this doesn't help please provide the model number and brand and I will do some more research.
Jan 02, 2009 | Milwaukee 5615 21 Factory Reconditioned 1...
How do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 29, 2008 | Makita 3612C Router
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Nov 13, 2008 | Dremel 300-N/55 300 Series Tool Kit
Dremel Plunge Router Attachment 335 Logo
44 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
