Question about Samsung Televison & Video
Reset samsung lcd screen - Samsung Televison & Video
    Top Expert:
  • Samsung Master
  • 75,581 Answers
If you wish to do a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This action will make the TV to a hard reset. If you wish to do a system reset, you have to enter its service mode option. For more details about how to enter the service mode, check the site linked here. It has details about how to enter, adjust and exit service mode to most popular brand TVs, including many models of Samsung. Pull up older posts.
Posted on Nov 26, 2013
I have a 46" Samsung LCD TV. The screen turned bright white. We reset display settings but didn't work. We're able to see image and get sound as well. Is this a t-con board issue? ln46a530p1fxzc.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 26, 2016 | Samsung Televison & Video
Samsung flickering fix
try this option reset settings to factory default
reconnect lcd cable from mainboard to lcd panel
Sep 05, 2014 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
AV1 remains in the upper left corner of the screen. Volume diagram remains in the center of the bottom of the screen. Both of these are on the screen all of the time.
This sounds like Screen-Burn which is very uncommon for an LCD TV.
You could try resetting the TV.
- Press and hold the 'Exit' button for 10-15 seconds.
- Follow on screen prompts to reset and retune.
Failing this it *Could* be screen burn.
Apr 26, 2011 | Samsung LN46A650 46 in. LCD HDTV
I forgot my phone lock code for a samsung s7220
For all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung-mobiles2.jpg *#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
Jan 15, 2011 | Samsung S7220 Cell Phone
My samsung a766 in in phone lock
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 12, 2010 | Samsung SYNC SGH-A707 Cellular Phone
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Samsung lcd LN32B360C5DXZA has green haze on screen
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 10, 2018 | Samsung LN32B360 32 in. LCD HDTV
Whole display is of reddish colour -Samsung 945NX LCD
try to update the lastest version of your video card driver
May 12, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
LCD Screen won't reset after unplugging
Try holding the top two buttons in for @ 12 seconds or until the unit beeps then realease them.
Oct 27, 2008 | Samsung RS2534 Side by Side Refrigerator
LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Mar 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
