Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
My Maytag Neptune Dryer electric dryer seems to work fine with one important exception -- whenever I run it, the laundry room fills with the strong smell of burning rubber or plastic. I do not see actual smoke. The vents are all clear. I'm afraid to run it anymore until I get it repaired. I'm pretty handy, but I've not ever cracked open an electric dryer. Thoughts? Clues? Questions? Help?
  • bandmaestro May 09, 2009
    It's model MD5500 (electric). It's not making any odd noises or any other symptoms. No squeaking. Just the smell of burning rubber while it's running. Could it be the belt? If it was slipping I would think it might make some noise. I read some of the other posts and see that circuit boards can fry. If that's it, will it hurt to keep running it until it just stops?
  • Mark Nichols May 11, 2010
    hmmm, any noise any other indications? let me get the model number and i can look it up
Hi all,
I had this exact problem, same model.
It's the door gasket !
I ripped it off, threw it in garage.
Problem solved !
Cheers!
Rock.
Colorado.
USA.
Posted on May 31, 2009
  • 351 Answers
Could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
    Master:
  • 492 Answers
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
Posted on May 08, 2009
Maytag Neptune Drying Center MCE8000AYQ Why does it not tumble?
I would start at a belt. Most cities have a do it your self appliance store, they can order you the part and ship it to your door or you can pick it up. Some Belts are as low as $16. Before condemning it is worth the gamble. Before Disassembing the unit go to U tube search out your dryer there should be an instructional video on how to replace it. Also pay attention to how the current belt is fed. I take a picture with my phone or diagram it. It helps especially if you get called away from the project. Hope this helps
Jun 21, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
What is small blue plastic wheel?
The small blue wheel, just next to the Motor, is the tension pulley, your belt should go around it, before going around Drum
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
2,274 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
