Question about Kenmore Dryers
Model 970 c85192 00
My dryer make a small noise when spinning. Can you tell me what could that be? It is not a belt noise i believe.
hunter19_46m
  • 7482 Answers
SOURCE: banging noise when the drum is spinning
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
You can get a parts manual from this website:
http://www.applianceaid.com/
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 13, 2009
dr appliance
  • 266 Answers
SOURCE: My Kenmore front loading dryer,
usually this is a drum roller replace both very inenspensive and u can order parts directly threw sears.com recheck model number get off appliance data tag on appliance
Posted on Jan 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: how to install a belt
Hi galante823...
I will also include a link to show you how to route the belt...
http://www.applianceaid.com/images/belt-config.JPG
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.Sometimes you have to use a flat bladed screwdriver to insert under the lid and pry up to remove the lid from the retaining clips.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 28, 2011
heatman101
  • 43501 Answers
SOURCE: my kenmore dryer is making
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 14, 2011
ferguste279
  • 3 Answers
SOURCE: can you stack a kenmore washer / dryer model #
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Posted on May 03, 2012
MDE9606YW
The motor could be going bad. Check your belt to see if it is loose . There is also a hub that the drum spins around. It could be loose. I believe you can oil it on this model as I have a Maytag as well. At least you have heat . This is just a physical problem and not electrical.
Mar 15, 2013 | Maytag Dryers
We took off the front of the dryer.. the belt needs replaced.. however there are two small wheels in the back that make the dryer spin.. and one is good, the other is very very loose and is making all the...
i believe you are talking about the drum roller here is a website with the part:
http://www.repairclinic.com/Dryer-Axle-Roller-Shaft-Wheel-Parts
there is a c-clip that you have to remove and it slips right out. Good Luck Tim
Apr 02, 2011 | Dryers
Dryer doesn't spin. Noise is present when dryer is turned on but no spin
I believe your belt has broken. Replace it, and all will be fine once again. The noise you hear is most likely the motor turning freely.
Hope this helps :-)
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Dryers
My Kenmore front loading dryer, 970-C85192-00 starts drying with a load squeaking noise. Once it warms up it stops. Could it be a belt?
Jan 28, 2011 | Dryers
I've got a Maytag model LD9206. It makes a lot of noise when it first starts up, but the noise goes away. The noise is a loud squeak which I believe is probably related to the belt or pullys. How do I...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 06, 2010 | Maytag Dryers
Model #970-c81032-20. Dryer makes high pitched squeal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 21, 2010 | Kenmore 83042 Electric Dryer
Whirlpool elec dryer, very loud and stops spinning.
The belt is probably bad and the noise is most likely the guide wheel for the drum
Jun 11, 2017 | Whirlpool Dryers
Banging noise when the drum is spinning
Good Luck,
I hope this helps
Nov 13, 2009 | Kenmore Dryers
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
