Question about Garden
Mastercraft snowblower snowblower dies out when under a load or when run for a period of time
    Scholar:
  • 61 Answers
You didn't tell us what you have for a motor in it ! Assuming you've already installed a new spark plug, depending on type of motor the following procedure will give you an idea if your possibly dealing with a fuel/carburetor issue. Find a way to shut the fuel off that is coming from the fuel tank to the carburetor. Find the carburetor and it's bowl some engines will have a screw or bolt that seats into the bowl which can be backed out to drain the contents of fuel and such. Others may have a push drain that if you look closely has a spring on it and a smooth topped pin of which you can push and drain fuel, yet another will be held by a what will look like a bolt coming straight up through the bottom of the bowl which can be removed. Which ever one you have drain that fuel that comes out into a clean container and look to see if there's any water or debris in it, if there is get as much out of the bowl as you can and drain the fuel tank and fuel to carburetor fuel line completely out. Add new fuel and restart and retry. Let us know if it doesn't run okay and we'll go from there but type and horse of motor size would be helpful. Good Luck!
Posted on Nov 26, 2013
2 Suggested Answers
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
Looking for a gas shut off valve for a Mastercraft 8/26 snowblower.
Just follow the tube under the gas tank. there should be a small valve on the tube itself.
Dec 18, 2016 | Garden
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
How do I start my Mastercraft snowblower
check gas and oil
check blower housing (round part) for ice and snow ( clear if needed)
put gas and choke on full
prime 3 times pull cord or hit electric start
repeat if it doesnt start with priming 3 more times
Jan 03, 2015 | Garden
Mastercraft 5 hp snowblower parts list
control cable for a snow blower model #31a612e515
Jan 15, 2013 | Mtd Snowthrower Snowblower 5 24" Parts...
I am looking for the user manual of my snowblower Mastercraft 22' 4HP
contact sears,is it made by sears? or go to mastercraft.com.
Aug 29, 2010 | Garden
I need a manual for a Mastercraft 8 Hp snowblower P/N 316 582 515
Jim
Dec 03, 2009 | Garden
I have a Mastercraft Snowblower that wont run. The primer hose is disconnected and I dont know where it is supposed to be connected to
there is a small tube on the side of carb that it hooks to,some times you need to pull the cover off the carb to see it.the other end goes to primer bulb.
Feb 23, 2009 | Garden
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Dec 18, 2008 | Mastercraft Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
