Question about Briggs & Stratton Measuring Tools & Sensors
CAN THE VALVE SPRINGS BE TOO WEAK CAUSING POPPIN THRU CARB ON 24 HP INTEK
    Problem Solver:
  • 16 Answers
I doubt it about weak spring, valves may need adjusting. use a .006 feeler gage on intake and exhaust both. with 1 tappet all the way down check the one thats up.
Posted on Nov 29, 2013
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: What engine oil is recommended for the Intek 24 hp
multi-grade will be fine it realy dont need a pricy oil in it this kind of engine will run on dirty cooking oil,,with or with out the chips still in it?
Posted on Mar 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My 24 hp intek is only running on one cylinder
Perform a compression test. As these engine age they are notorious for getting carbon under the exhaust valve heat in the seat area. What happens is you get a tiny piece of carbon under the head.... the valve cycles with the cylinder but does not close. Actually it can be either the intake or the exhaust valve but more often that not it is the exhaust valve that is the culprit. Worst case you hand lap the valve to the valve seat with grinding compound.
Another thing it can be is a hole in the piston. (VERY rare)
Both would cause a compression test to fail. You don't even need a pressure gauge. You can sacrifice a small paint brush handle and compare the good cylinder to the bad one by the amount of pressure you get but holding the brush gently in the spark plug hole. Just make sure your back yard pressure checker (paint brush handle) does not protrude into the cylinder so far that it can be hit by the piston. I am thinking you will have one very strong cylinder and one very weak cylinder. It is not a hard fix... it is a matter of making sure the valves seat properly on the bad cylinder. Now if the piston has a hole in it... now you talking much more work. I may be able to find a service manual for you if you discover there is a hole in the piston. Not sure if the service manual will be free or a purchase item because I have not looked yet.
Thanks for choosing FixYa.
Kelly
Posted on Jul 27, 2010
I'd l100 31f707 carb adjustment
you will have to bend throttle tab if not buy carb 80.00
Oct 16, 2014 | John Deere Garden
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How tocheck timing onbriggs stratton model44577
The timing is fixed, if you suspect the timing is off the only adjustments available are the .030 clearance from pickup to flywheel and the shear Key that positions the flywheel on the crankshaft. You would also want to make sure your valve clearance is .030 as well, the issue sounds like a valve leaking, a dead cylinder or mal adjusted valve clearance causing the exhaust valve to hang open just a bit.
May 13, 2014 | Briggs & Stratton Briggs Stratton Intek V...
POPPING THRU CARB RUNS GOOD AT HIGH REVS ON 24 HP INTEK
I would lean more to the key on flywheel being partly sheered which will throw the timing off. that will happen if the motor has a sudden stop or jolt while running.
Nov 25, 2013 | Briggs & Stratton Measuring Tools &...
Popping thru carb, checked timing its ok,the push rods on three rocker arm hardley move one opens good, problem started all of a sudden.
INtake valve adjustment needed. at least on one cylinder. maybe both sides. while your in there adjust all. must have some clearance. .004 on intake .006 on exhust.
Sep 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18.5 hp intek started this summer when it has
more so a head gasket blown internally causing positive crankcase pressure, & forcing oil out the breather into the carb.
Aug 18, 2009 | Poulan Garden
Measuring Tools & Sensors Logo
54 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
