Question about Briggs & Stratton Measuring Tools & Sensors
POPPING THRU CARB RUNS GOOD AT HIGH REVS ON 24 HP INTEK
    New Friend:
    Problem Solver:
  • 16 Answers
I would lean more to the key on flywheel being partly sheered which will throw the timing off. that will happen if the motor has a sudden stop or jolt while running.
Posted on Nov 29, 2013
  • 21 Answers
SOURCE: popping thru carb, checked timing its ok,the push
INtake valve adjustment needed. at least on one cylinder. maybe both sides. while your in there adjust all. must have some clearance. .004 on intake .006 on exhust.
Posted on Sep 26, 2010
  • 32 Answers
SOURCE: 22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Posted on Jul 20, 2009
SOURCE: 21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Posted on Nov 07, 2009
miket756
  • 2702 Answers
SOURCE: What engine oil is recommended for the Intek 24 hp
multi-grade will be fine it realy dont need a pricy oil in it this kind of engine will run on dirty cooking oil,,with or with out the chips still in it?
Posted on Mar 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My 24 hp intek is only running on one cylinder
Perform a compression test. As these engine age they are notorious for getting carbon under the exhaust valve heat in the seat area. What happens is you get a tiny piece of carbon under the head.... the valve cycles with the cylinder but does not close. Actually it can be either the intake or the exhaust valve but more often that not it is the exhaust valve that is the culprit. Worst case you hand lap the valve to the valve seat with grinding compound.
Another thing it can be is a hole in the piston. (VERY rare)
Both would cause a compression test to fail. You don't even need a pressure gauge. You can sacrifice a small paint brush handle and compare the good cylinder to the bad one by the amount of pressure you get but holding the brush gently in the spark plug hole. Just make sure your back yard pressure checker (paint brush handle) does not protrude into the cylinder so far that it can be hit by the piston. I am thinking you will have one very strong cylinder and one very weak cylinder. It is not a hard fix... it is a matter of making sure the valves seat properly on the bad cylinder. Now if the piston has a hole in it... now you talking much more work. I may be able to find a service manual for you if you discover there is a hole in the piston. Not sure if the service manual will be free or a purchase item because I have not looked yet.
Thanks for choosing FixYa.
Kelly
Posted on Jul 27, 2010
CAN THE VALVE SPRINGS BE TOO WEAK CAUSING POPPIN THRU CARB ON 24 HP INTEK
I doubt it about weak spring, valves may need adjusting. use a .006 feeler gage on intake and exhaust both. with 1 tappet all the way down check the one thats up.
Nov 25, 2013 | Briggs & Stratton Measuring Tools &...
My 24 hp B&S starts and runs good for 1/2 hour then it will not start when you try to start it. After it sits over night it will start and run for 1/2 minute then quits and will not start again.
Running for 1/2 minute then stopping sounds like the carb's fuel bowl is starving for fuel. I would check the carb's float and needle and seat to verify it is not sticking. Usually when the engine runs there is enough vibration to unstick it. I would also look at fuel filter (disconnect the fuel line to the carb and verify that fuel flows freely - try not to spill too much).
Jul 01, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a Intek Twin 24 ohv engine. It will only run smooth if the choke is half open. If the choke if fully opened, the engine is unsmooth and revs high to low by itself. I tried cleaning the carb but...
I had problems with my 20hp v twin.The fuel was the problem.I stopped using fuel with ethanol.Problem solved.My 60 hp Evinrude had the same problem.Ethanol was responsible for eating away gaskets and o-rings.This stuff also eats away at some aluminum carbs.Thanks congress for voting to add this **** to our fuel.Wish you would pick up the repair bills too.
Nov 13, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Popping thru carb, checked timing its ok,the push rods on three rocker arm hardley move one opens good, problem started all of a sudden.
Sep 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18.5 hp intek started this summer when it has
more so a head gasket blown internally causing positive crankcase pressure, & forcing oil out the breather into the carb.
Aug 18, 2009 | Poulan Garden
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Jul 09, 2009 | Garden
Measuring Tools & Sensors Logo
56 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
