Question about Moultrie MFH-DGS-100V2 Digital Camera
Camera does not take pictures and drains battery overnight
Any battery used is drained overnight
My Samsung ES15 camera drains the batteries after 3-5 pictures are taken.
What batteries are you using ? Some batteries, although the correct nominal voltage for the camera, are not powerful enough for continued use. I have found the best solution is to use rechargeable NiMH batteries of at least 2100 MaH, preferably 2500 MaH.
Aug 01, 2016 | Samsung ES Cameras
Check battery drain using test light
Check for any of the interior lights especially the glove box staying on, or one of the door switches stuck in the on position.. Other option is to pull all the fuses, then replace them one at a time overnight and monitor the battery. Soon as the battery gets drained you've found the circuit causing the problem, then troubleshoot that circuit.
Aug 25, 2014 | Cars & Trucks
2013 taurus with viper 211hv remote entry drains battery overnight.
If your battery is draining overnight and, you attribute it to the alarm, it could be a improperly installed starter kill relay. If the relay is wired to battery instead of ignition will do it.
Feb 19, 2014 | 211HV Keyless Entry System
Batteries are being drained. We barely use our camera and the batteries are being drained after only a few photos being taken. Camera is rarely used, maybe twice a day. At the most 5 pictures per day. ...
there seems to be a short if you have already tried replacing the batts then yes there is a short taking the power have it looked at by a lic pro
Jun 18, 2010 | GE A830 Digital Camera
It won't stay on even with new batteries.
With 206,000 hits when you type 'Finepix A700 problems', it is MORE than just batteries!!!! The camera model was pulled off the market because it has real issues internally draining the battery if you go to view your pictures. I hear there is a factory fix for it if you want to pay them. I haven't called them yet.
Nov 26, 2009 | Fuji FinePix A700 Digital Camera
Batteries drain after only 5 or 6 pictures
New camera?...take it back.
Aug 25, 2009 | Cameras
The old canon A1
Dear FreshEarth,
This is definately not a common problem the battery under normal use should last about a year. I beleive what is causeing this is you either have the exposure preview switch or the exposure memory switch turned on causeing the exposure meter to be taking a reading all the time and draining the battery. Those switches are located on the front of the camera to the left of the lens. If this doesn't resolve the issue I would have the camera looked at by an camera repair technician.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Konica Minolta DiMAGE Z10 Battery Leak
It sounds like a short in the circuit board. Not worth getting fixed unless you find a local person. but first try puting a set of lithium batteries in. sometimes those last forever even when other batteries last less than 10 shots.
other wise try takeing the batteries out whenever you are done and see how long they last that way. then you will know if it is a short if they last a long time.
Hope That Helps,
Caleb
Feb 09, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Aug 29, 2005 | Fuji FinePix S7000 Digital Camera
Moultrie MFH-DGS-100V2 Digital Camera Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
