Question about RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray hard to turn
Very hard to turn side to side
    Top Expert:
  • RTO Master
  • 12,223 Answers
Make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Posted on Nov 26, 2013
Jameco single handle kitchen faucet with spray is hard to turn
make this steps and fix it. God bless you
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Our jameco kitchen faucet has no water pressure. also we have a slow leak on the cold water side. The faucet is only 3 years old. we took the cold side apart and there is no washers, only an o ring that...
Sounds like you may need to replace the cartridge if you have one of the late model single control models. You may get a clue as to how your faucet might be put together by finding a similar faucet on the Moen web site, and looking at their exploded parts diagram. (They are good about posting information; although some say their products are not so good; I really don't know personally)
Dec 14, 2009 | Delta 2402 Classic Single Handle Kitchen...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
RTO Jameco #K-1320B Bone Drop In Lav Sink Logo
171 people viewed this question
Top RTO Home Experts
Mike
Asian-gem
Asian-gem
Level 1 Expert
Gene Haynes
Are you a RTO Home Expert? Answer questions, earn points and help others
