Question about Acer Aspire Timeline X 4820t-6447 Core I5 2.66ghz 14.0" Led Display 4gb/640gb
Acer 4820T refuses to play DVD
I have just booted up my laptop and put in a DVD, but nothing happened. Autoplay hasn't run, and the CD drive appears to have disappeared from 'Computer'. I've had this problem before and have previously solved it with the old 'switch-on-switch-off' routine, but that hasn't worked this time. I have previously watched this DVD with no problems, and the drive was working perfectly the last time the laptop was on (less than 24 hours ago) Under 'Device Manager' the driver seems to be enabled, says its working fine and doesn't need any updates. I don't know if it's relevant but one thing that I have noticed - when looking at the properties of the device it says it is set to region 1, whereas I am region 2. I haven't changed this myself previously, and it won't let me change it now. Any advice much appreciated :)
  • 106 Answers
Please check for "Auto play" option [by typing 'auto' on the search space just above the Start button] and chech for enable/disable as required by you on cd/dvd drive and save it[Please disable it for "removeable drives" to save your computer from 'autorun virus'. 1. Disconnect the optical drive from your laptop, 2. Update thechipset+USBhost drivers from the Acerwebsite 3.reconnect it restart it and try Good Luck!
Posted on Nov 25, 2013
  • Samuel Konger
    Samuel Konger Nov 25, 2013
    If it is running on Windows 7, Please type 'Autoplay' on the search box just above the Start button and check enable autoplay on cd/dvd drive for the type of file and program you'd like it run but please uncheck it for pendrive/removable drives to protect your computer from 'autorun virus usually transfers through removeable drives. then follow these steps: - 1.. download and install chipset and USBHost drivers from the manufacturer's(Acer) website according to model number, 2. remove the optical drive from your laptop, 3.reconnect the cd/dvd drive, 3. restart the Laptop! Good luck!.
  • 244 Answers
SOURCE: Acer aspire 5102 orbicame solution
Try to reseat the camera cable, it's under keyboard. ussualy it will work. If after reseat camera cable, it still doesn't show in device manager, your orbicam might be bad.
Posted on Feb 17, 2008
sandrew
  • 2961 Answers
SOURCE: Problem with Acer Orbicam aspire 5102WLMi not working
you have chosen the wrong driver, go to the link below and choose orbicam (logitech) not the Bison one
http://support.acer-euro.com/drivers/downloads.html
Posted on Aug 23, 2008
  • 461 Answers
SOURCE: Acer 5580 Bluetooth and USB port problem
There may be a bent connector on one of the USB ports or a defective USB controller on the motherboard. The bluetooth connector may not have been reconnected or the bluetooth module was not reinstalled after service. Sadly you will need to have it serviced again. They most likely will not replace it it with a new laptop, but maybe a refurbished one. You could push for a warranty extension for amount of time the system has been due to need of repair. Good Luck.
Posted on Dec 06, 2008
  • 67 Answers
SOURCE: Acer 5100 cd/dvd drive no longer appears as a device - anywhere
try a disk cleaner it might be dirty inside and they are very sensative
Posted on Dec 21, 2008
colt_baldwin
  • 103 Answers
SOURCE: acer aspire can't find the dvd to play cd's
In the device manager, select the DVD ROM and UNINSTALL / REMOVE the device.  Restart Windows . . . did this work?  If not, boot into your CMOS and see if the drive is being detected by the motherboard... if yes, look further and make sure the settings for the drive are correct. Make sure that all IDE interfaces are enabled in the CMOS settings (both)
Posted on Dec 25, 2008
Why won't my Acer laptop play compact discs?
Most units are designed to "autoplay" audio CDs when they are inserted. When they fail to do so, it could be because the CD is dirty or scratched and was bot recognized, the media player that you are using to play the CD was not in a state that it could autoplay the CD, or there could be a problem with the Disk drive or PC itself. Whenever a CD fails to play upon insertion, go to the "My Computer" icon (win7 or below) and see if the CD/DVD drive shows a disk inserted. If so, clicking on the drive will often start the playback.
Dec 30, 2014 | Acer Aspire 5100 Notebook
External DVD drive won't play DVD moies
Looks like you need a decoder
http://windows.microsoft.com/en-us/windows7/play-a-cd-or-dvd-in-windows-media-player
Feb 09, 2014 | Computers & Internet
I have a Toshiba Laptop which when either CD or DVD starts but nothing appears on screen and the disc stops after a few seconds can you help??
are you talking about when windows is loaded? I guess my question is are you asking about autoplay, or are you talking about trying to boot from a disc, if it's during boot, you can either press f12 to get to the one time boot menu and choose your dvd/cd drive, if you're talking about windows you can do this: Go to Control Panel\Hardware and Sound\AutoPlay. To Enable: At the top, check Use Autoplay for all devices and Click Save.
May 11, 2012 | Toshiba Computers & Internet
I have the 2010 academic version of peachtree complete and when i put the disc in the cd-rom nothing happens. You can here the disc spinning and can my pc is trying to read the disc but then the spinning...
You computer probably has Autoplay turned off for security.
-Click the start button on the lower left and click Computer when it appears near the middle of the right column. -Look for one of the drives labeled CD or DVD, probably the D drive. Righ-click it's icon. -From the list choose Autoplay.
If Autoplay is not an option double-click on the CD or DVD drive. Look for an application called Setup and double-click it to begin setup.
May 17, 2011 | Sage Software Peachtree Complete...
My CD ROM's Auto-load/Auto-exe is not working. I put in CD software and it doesn't load it. I put in a DVD movie and it doesn't auto-play.
Enabling AutoPlay in Windows XPEnable through Windows Explorer
  1. Open My Computer or Explorer
  2. Right-click the CD-ROM drive or other drive and click Properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
Enabling AutoPlay in Windows7 and Vista
http://www.techtalkz.com/windows-7/516004-how-configure-autoplay-settings-windows-7-a.html
Aug 23, 2010 | HP Pavilion dv6000z Notebook
Laptop has lost dvd.. it can not open or play anything
if you want to save the autoplay option to certain drives (e.g. CD/DVD drives) ... I have problem with hard disk, It is not open when I double click. ... If you cannot find the file, it's probably because windows lost it or you have a virus. ..... I still wanted my CD-ROM to use this feature but not anything else. ...
www.howtogeek.com/.../disable-autoplay-of-audio-cds-and-usb-drives
Dec 03, 2009 | Acer TravelMate 4200 Notebook
When i put a dvd or cd in it doesnt play
you should check what brand and OR number it has and i will help you when you have that
Oct 24, 2009 | Acer Windows Vista TL-562G Notebook
My CD/DVD player on my laptop wont work???
go to my computer and right-click on your drive and say autoplay, does that work?
Feb 17, 2009 | Acer TravelMate 223X Notebook
ACER ASPIRE 4315 DVD drive not recognised
See if your DVD drive is recognized when you boot. To get in the Bios, when logo appears during booting, hit "delete" or "F2" or whatever you are prompted.
Also, see that it is reconized without any marks in the Device Manager, once you boot OS.
Jun 01, 2008 | Computers & Internet
My Laptop won't play Cds or Dvds
see if it can still boot the cd , put in a windows cd
go into the bios and set the cd as boot device in boot order.
save and exit with cd in drive
you will get a prompt at boot to press any key to boot cd
do this and let it run until the next prompt screen then exit .
if it never will boot the cd , time to replace drive.
Apr 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire Timeline X 4820t-6447 Core I5 2.66ghz 14.0" Led Display 4gb/640gb Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
