Question about Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
My flat screen got smashed so a neighbor gave me an old magnavox 27ms343s (which am grateful for) , it worked fine when I first got it but when i turned it on this morning the picture was huge almost like it was stuck on wide screen or zoom. I checked all of the settings on the tv and cable box and all of those settings are fine. I know its the tv because when I turned on the game system I had the same problem. Is there anything I can do to fix this or is the tv just going out ?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
You may have pressed the smart picture key on the remote.
SmartPicture: Lets you set the picture's color, tint, contrast, etc., for various types of programming. Settings include Sports, Movies,Weak Signal, and Personal, which sets the picture controls as you want.
1 Press SMART PICTURE on the remote control.The current SmartPicture setting will appear on the screen.
2 Press SMART PICTURE repeatedly to select PERSONAL, MOVIES, SPORTS, or WEAK SIGNAL. The PERSONAL setting is what you specify with the picture adjustments as described on page 15. PERSONAL is the only SmartPicture setting you can change. All others are set at the factory during production.
Posted on Nov 25, 2013
    New Friend:
Take of the back and there is buttons inside, try turning them.
  • 18 Answers
SOURCE: need to degauss a magnavox tv
Why do you think it needs to be degaused? What are the symptoms?
Posted on Aug 19, 2007
techman
  • 3130 Answers
SOURCE: Magnavox 27MS343S 27" TV
You will for sure need to borrow a remote from someone to do this. But I will give you the way to unlockit just in case you can get one. Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Posted on Aug 31, 2007
dmathwizard
  • 113 Answers
SOURCE: Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Posted on Mar 05, 2008
SOURCE: Philips Magnavox 27MS343S 27"
WHAT IS THE CODE TO PROGRAM A J.V.C. DVD INTO A PHILLIP UNIVERSAL REMOTE?
Posted on Apr 08, 2008
  • 79 Answers
SOURCE: TV keeps shutting off and changing channels
hide all your remote controlls and put some tape over the front cover of the tv where you think the remote control reciever may be , if this fixes it then it means something is amiss with a rogue remote , most likely batterys..could even be sunlight ??
Posted on Jul 03, 2009
Child lock on
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Unlock procedure to many popular brand TVs are given.
Mar 31, 2014 | Philips Magnavox 27MS343S 27" TV
I need a remote for my television
This link will assist you with getting a remote that will work with this television.
http://www.replacementremotes.com/PHILIPS/Buy-996500015582-Remote-Control.html
Mar 29, 2011 | Philips Magnavox 27MS343S 27" TV
Cannot get the full picture on screen
if you zoom it and it did not work then your problem is in the vertical circuit
May 23, 2010 | Philips Magnavox 27MS343S 27" TV
Tik tik sund from philips tv
when i turn on my philips 20 in flat tv i have no picture, just black screen with a tik tik sound
May 11, 2010 | Philips Magnavox 27MS343S 27" TV
Apr 08, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
1998 27' magnavox tv/combo
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
Sep 09, 2007 | Philips Magnavox 27MS343S 27" TV
Need to degauss a magnavox tv
Aug 18, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
127 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
