Question about Bosch 800 B26FT70SNS 25.9 cu. ft. French Door Refrigerator with Adjustable Spill-Proof Glass Shelves, Exterior Ice/Water Dispenser, VitaFresh Food Preservation System, SuperFreeze and Multi-Level LED Lighting
Everything in fridge is freezing bosch french door B26FT70SNS
How do I fix my icemaker?
if its new it can take up to 48 hrs to produce its first ice cubes, this is due to timer in the ice maker
Nov 07, 2015 | Bosch B26FT70SNS - 800 Series Standard...
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug.
This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old.
Hope this helps. Best wishes!
Jul 23, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Bosch 800 B26FT70SNS 25.9 cu. ft. French Door Refrigerator with Adjustable Spill-Proof Glass Shelves, Exterior Ice/Water Dispenser, VitaFresh Food Preservation System, SuperFreeze and Multi-Level LED Lighting Logo
24 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
