Question about Konica Minolta Bizhub C550 Color Copier/printer/scanner
My Konica Minolta C550 keeps having paper jam at the red laser rollers. It does not print 2 sides anymore. It sometimes crimp into a fan like manner. Please help me with a solution to my constant pape
Keeps jamming the paper at the red rollser
I am pretty sure the red heat roller is delaminating and will require replacing, try and get a refurbished one half the new price.
Posted on Dec 07, 2013
2 Suggested Answers
SOURCE: Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9.  What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them.  After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
Posted on Nov 16, 2007
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
May 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Paper jam laser
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Nov 25, 2013 | Konica Minolta Bizhub C550
Hi, my magicolor 2300 w is doing a noise when trying to use the red color and the paper is printed without red color
Have you got another cart to test it with? Sounds like roller in red is jamming. Remove it and reseat it again.
Dec 30, 2010 | Konica Minolta magicolor 2300DL Laser...
Konica Minola 2300DL laser printer. When I try to print, it jams at the printer rollers just before the paper ejects. It fan folds in the top rollers There is no paper stuck anywhere?
I would closely examine the exit roller. When the paper fans; it's sticking on something. Typically, stuff will ":hide" on rollers; or maybe stuck on a sensor. Using a good flashlight will help.
Oct 27, 2010 | Konica Minolta magicolor 2300DL Laser...
C550 making a squeeking noise
A squeaking noise? The first possibility is a remnant of paper from a paper jam, causing the noise. You may be able to isolate this to a paper draw issue. To do this, remove all but one of the drawers. Do a test copy. Repeat this until all drawers have been eliminated. If it is a paper drawer issue, the take-up rollers (in the middle of the take-up edge) can be cleaned with a cloth dampened with mild liquid soap. If it isn't a paper drawer, the next possibility is the paper-path, up the right hand side of the copier. There are a number of 'doors' that can be opened. Check that the rollers and paper path is clean. If these two possibilities are eliminated the next issue is the fuser unit, the transfer unit, the toner cartridges or a cooling fan. These items should be directed to a service technician.
Sep 01, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Tray Jamming
Sounds like the rollers are having issues. You could call the manufacture and get a local repair shop to switch out the rollers for you.
Jul 16, 2007 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta Bizhub C550 Color Copier/printer/scanner Logo
109 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
