Question about Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 Using windows xp cannot access speedstream 5200 dsl modem tried 192.168.254.254 any suggestions?
  • Anonymous Dec 29, 2007
    Will not pull up the ie. I've put in the correct numbers and nothing works. I am also running window xp
    Brooke
  • aldebaro Dec 29, 2007
    Have a similar problem: I can login using the web interface, but cannot using telnet (providing the same username/password).
Http://192.168.2.1/ just type it in internet explorer address bar
Posted on Apr 05, 2008
Maybe you should also take a look at
http://www.dslreports.com/forum/remark,15033027
But I have not myself managed to make telnet work.
Posted on Dec 29, 2007
Posted on Nov 12, 2007
    Problem Solver:
  • 8 Answers
Here is the pdf download link for this modem
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
should be of some use
Posted on Oct 19, 2007
I have the speedstream 5100 modem. I just replaced my xp machine with a windows 8 and I can't get to the internet now. It tells me ethernet doesn't have a valid IP configuration. Any sugges
If you do not have a router you have to reboot the modem first, Modems pair with one device at a time using its MAC address, using a router allows you to add remove computers to your internet access without rebooting the router for every device because the modem pairs to the router and the router shares its internet with your other devices.
Jan 28, 2013 | Efficient Networks SpeedStream 5100 Modem
I can't get my Siemens SpeedStream 4100 to work with my new AT&T DSL service. I used to have DSL through a local company, Humboldt Internet, but they stopped offering DSL and sold off their DSL...
When you are connecting to it, are you using the lan connection straight into the device? When you do that is it showing as at least connected to the device on the computer? You did not post the operating system but can you check the router address by using the command prompt and using tracert commands to see what it is listed as? If you are using windows 10 have you use the powershell command to reset the winsock? Did you use the 30 30 30 reset method on the device?
Feb 27, 2017 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 nat
you should be able to access your modem in your web browser using 10.1.1.1 as the address . if u haven't changed the password and user name they should both be admin. once in the settings change from static IP to dynamic ip this should solve your connection problems
Nov 15, 2007 | Efficient Networks SpeedStream 5200 Modem
Efficient Networks SpeedStream 5200 Modem Logo
835 people viewed this question
Top Efficient Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
