Tv has lost its color
My apex tv is suddenly showing everything in black and white mode... whered the color go? how do i get it back?
  • 1 more comment
  • Ghetto_cowbo May 08, 2009
    i don't know why this post went under projection tvs, its a regular flat pannel tv an Apex 20"
    how do i do that?
    i dont have a remote :(
  • 375 Answers
SOURCE: Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Posted on Sep 08, 2007
  • 556 Answers
SOURCE: color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Posted on Oct 02, 2007
  • 18 Answers
SOURCE: Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Posted on Dec 27, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Posted on Jan 15, 2008
SOURCE: Can't get normal color in video mode.
We just solved this problem! Rotate the wheel button (above the Display & Menu buttons) to see the various option (Color Accent, Color Swap, Compact, etc.) and stop when you get to Standard.
Posted on Jan 16, 2008
My lg tv lost its color. I ma watching it in black and white. does this mean it is dying?
Are any of the other inputs such as DVD or VCR or PC inputs out puting color? If they are also only in Black and white they something has gone wrong inside on one of your main boards.
I'm wondering what input you are using.
HDMI
Component
S-Video
Composite
May 24, 2012 | LG Televison & Video
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
TV is in black and white when trying to play the XBOX 360. When it is on Direct Tv it works fine in color.
May the current setting of your TV is NTSC and Just check your screen setting and bring to auto mode
Dec 25, 2010 | Apex Digital LD4088 LCD TV
Nissan Murano monitor not showing in colour
Is there a setting on there where you can change the picture from color to black and white.
Jul 10, 2009 | 2005 Nissan Murano
We have an Emerson 20inch tv that suddenly lost it's color.
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 26, 2017 | Emerson EWL2005 20 in. LCD Television
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Color in black and white
Possible solutions....
1) These Apex players can handle multiple sytems (NTSC/PAL)
Is it possible it is switched in the wrong mode?
Follow the jumpy picture and enter the menu to see if it is switched in the PAL mode (You may have to follow the user manual and try to look at the screen carefully while following to menu flow)..
Some APEX units have a button on the remote to switch the systems.
2) I have also seen some TV's that will not handle the progressive scan mode...
Try switching in the menus.
Mar 01, 2009 | Apex Digital AD-2500 DVD Player
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
DVDs are only in black and white
Jimbo.. is your new TV HD compatiable??
Nov 11, 2007 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
