Question about Konica Minolta Bizhub C550
Paper jam laser
My Konica Minolta C550 keeps having paper jam at the red laser rollers. It does not print 2 sides anymore. It sometimes crimp into a fan like manner. Please help me with a solution to my constant paper jamming. Thank you
  • 998 Answers
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Posted on Nov 25, 2013
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
herminio_hal
  • 210 Answers
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Posted on Jul 09, 2009
  • 1297 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
SOURCE: Konica Minolta flashes error light and wont print.
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta c550 printing dirty background on Thick Paper
Id start with a transfer roller, A00JR71500. Could also be your black drum.
Apr 04, 2014 | Konica Minolta bizhub Office Equipment &...
Hi, my magicolor 2300 w is doing a noise when trying to use the red color and the paper is printed without red color
Have you got another cart to test it with? Sounds like roller in red is jamming. Remove it and reseat it again.
Dec 30, 2010 | Konica Minolta magicolor 2300DL Laser...
Konica Minola 2300DL laser printer. When I try to print, it jams at the printer rollers just before the paper ejects. It fan folds in the top rollers There is no paper stuck anywhere?
I would closely examine the exit roller. When the paper fans; it's sticking on something. Typically, stuff will ":hide" on rollers; or maybe stuck on a sensor. Using a good flashlight will help.
Oct 27, 2010 | Konica Minolta magicolor 2300DL Laser...
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Tray Jamming
Sounds like the rollers are having issues. You could call the manufacture and get a local repair shop to switch out the rollers for you.
Jul 16, 2007 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta Bizhub C550 Logo
130 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
