Question about Hotpoint Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
  • Hotpoint Master
  • 2,128 Answers
You should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Posted on Dec 08, 2013
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
WhIzAtIt
  • 136 Answers
SOURCE: Used as beer fridge but contents freezing
The defrost timer in the unit is probably bad take a look at it there should be a timer with a slot in it around the thermostat that you can turn with a common screwdriver the timer should click and go into defrost mode and the unit should shut off, if the unit shuts off and it still doesn't defrost you either have a thermal cut-out that is bad in the freezer next to the heater element or the heater element itself is bad. Let us know :-)
Posted on Sep 15, 2007
IB4G2008
  • 3587 Answers
SOURCE: top shelf on refrigerator side freezes everything into ice
well..that's most likely due to a problem with the relationship between the control and the compressor.
is your unit under warranty?
Posted on Jun 03, 2008
darjr
  • 378 Answers
SOURCE: My fridge is freezing things on the top shelf
meaning you have a uncontrolled compressor it run continuously without monitoring the temperature, The Temperature control or Thermo control switch. will switch ON the Comp. untill the preset temp. is obtain then Sw. OFF if the temp is out of preset value.
Posted on Jun 07, 2009
woodchuck789
  • 4059 Answers
SOURCE: Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 12, 2009
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Jul 12, 2009 | Refrigerators
Jun 07, 2009 | Refrigerators
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
247 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
