Question about Edge Barricade 4 Port Broadband Wireless Rtr SMCWGBR14 N Lan Wan Inter
SMCWGBR14 N only power led
The router reset 1 time ( itself ), and work normally. 1 hour later, 2 more reset, and then only the power led is on ( in green ) and no other functions can be made, and no detect any connections from LAN or WAN. I try the reset, but nothing happened ( always green power led ). Any suggestion ? Thanks in advance
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Resolutions:
1) Power on the SMC modem / router and wait until all the lights are light up.
2) Press and hold the reset button for 15 seconds and wait until all the lights are light up as the modem / router needs to reboot.
3) Try to access to the admin page again by default login IP - http://192.168.2.1/.
4) Enter the default login password.
a) smcadmin
b) (blank)
c) barricade
Posted on Nov 25, 2013
Testimonial: "Thanks for your post. Normally will do that, but now only one led ( power led ) is on. I try holdin the reset button for 1 min, and the led is off for 1/2 second, and again only the power led is on."
Hi! My LG Refrigerator gr-L247 after a power shortcut of around 3 hours it is not working.
I have read stories of some tv's doing the same thing after the power is cut off and you have to wait for a few hours for unit to "reset" itself. Contact LG for their feedback on this. Could be an issue with the electronics of unit.
Aug 22, 2016 | LG Refrigerators
Reset tablet c
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the powericon1.png off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if theLED lighticon1.png flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
[Answer supplied by Aris C on Fixya.com]
Jan 22, 2014 | MSI Computers & Internet
How do I reset my SMC barricade g router?
hi Eric,
To Reset the newer Barricade Router, use the RESET button on the Router. It is found on the rear panel (except 7004ABR/7008ABR, where it is found in the front). It's a small pinhole blue button. Use a paperclip / pen / pencil to hold in. Reset can be done in following ways. If you find Power LED blinking, then it indicates a successful RESET......
Procedure 1 -
Unplug all the cables except the power cord.
While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Procedure 2 -
1 - Unplug all the cables except the power cord.
2 - While the Barricade is powered ON, Hold the RESET button for 5 seconds.
3- While holding the RESET, turn OFF the power to the Router.
4- Continue to hold it for 5 seconds, then turn ON the power to the Router.
5- Wait for another 5 seconds and then release the RESET button.
Procedure 3 -
1 - Unplug all the cables except the power cord and Power ON the Router.
2 - Hold the RESET button for 3 seconds.
3 - Release the RESET button for 2 seconds.
4 - Continue Steps 2 and 3 for Four more times.
Sep 03, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
Trouble alarm every 12 hours
Here is a link to instructions to access web based control of alarm unit.
http://www.smarthome-products.com/productspecs/DSC/TL-150-Manual.pdf
Hopefully you can log into it and find where to set time server, or at least set time/date.
Aug 14, 2017 | DSC Tl-150 Ip Communicator Lan Wan Network...
I need the reset codes for my dishwasher. It gets stuck in demo mode at times. That's what the repair man said who came last time. My dishwasher is the Whirl Pool Quiet Partner I, Model Number...
Hi, this is the reset code: Push/Press 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later it will start working....
Jun 11, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
We have a 3CR858-91 3com router and nobody knows it's administration password. I have tried to reset it to the factory defaults using a RJ45 cable (DSL port to LAN port connected) but it does't work (even...
I have same problem. So the solutions is (in my particular case), when you done everything as it written in the reseting instruction. You face blinking LAN/WAN ports and no any activity with Alert LED. After 30 second or even 1 min (i don't relly know do you need to wait or not), i disconnected LAN/WAN ports and connected it again without repowering. Then Alert LED starts to blink slowly every 2 second. After re-applying power it was reseted.
Mar 29, 2010 | 3Com 3CR858-91 Office Connect Cable/DSL...
Netgear Router WGR614 Problem, 1234 Lights Lit Orange, No Connect
Try resetting the Netgear back to the factory default and then configure the wireless setting.
Press the pinhole RESET button on the back of the Netgear until all the LEDs flash then connect a LAN cable from the computer to the Netgear open a browser and enter the configuration URL IP address
http://192.168.0.1
Jan 01, 2010 | NetGear WGR614 Wireless Router
Forgot password and username
Yes there is.
1. First turn the power off the router and press the "reset" button.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Feb 05, 2008 | Belkin (F5D7230-4) Router (587009)
Edge Barricade 4 Port Broadband Wireless Rtr SMCWGBR14 N Lan Wan Inter Logo
96 people viewed this question
Top Edge Computers & Internet Experts
Steven Conroy
Steven Conroy
Lee Durbin
Lee Durbin
Are you an Edge Computer and Internet Expert? Answer questions, earn points and help others
