Question about AdobeAir Alpine® RW4500 Thru-Wall/Window Air Conditioner
Looking for a remote control for a mv30a MasterView by MasterCool from Adobe Air.
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Any idea where to get the HI-Low motor control switch from model MMB10B? Adobe air inc seems to be out of busniess
I will advice you check ebay.com or ereplacementparts.com to search for the parts needed for your unit.
Jul 27, 2011 | Mastercool Portable Air Conditioner
All was replaced last year pump,filter,belt,but nothing is wanting to fire up
Is the circuit breaker turned on? Is there power at the controler or control box? Is there a blown fuse in the unit? Is it remote controlled or on a lead through the wall?
Apr 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need to know the difference between a master cool and a ultra kool
They are pretty must the same design, the Mastercool was made with heavier metal. But Mastercool are no longer being made,,,, so I guess if it's a new one you are looking for,,, Ultra Cool it will be.
Good Luck,
Paul
Mar 25, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need some help knowing the pump I need
Since adobe air is out of business, you will have to make one of the dial 230 volt pumps fit in its place. I cut a little notch into the media support tray to fit mine.
As far as the pump size goes, the orange 230 volt is somewhere around 11'000cfm or bigger and works just fine in my precooler.
Aug 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
AdobeAir Alpine® RW4500 Thru-Wall/Window Air Conditioner Logo
94 people viewed this question
Top AdobeAir Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
