I need to install windows 8.1 in Asus F5R (Core duo processor) and also need it's driver disk for windows 8.1. Please help!
Thank you for your sharing and i would like to share my experience with you, i got a good windows last week, it is genuine and cheap, https://www.facebook.com/Office-2011-for-MAC-Key-1799093256986418, posts which cost me a little money and works well now, you can find all relevant keys there, strongly recommend it to you, the customer service is quiet well.
SOURCE: VGA Driver Not Found for Asus X95GL WinXP 2002 Pro SP2
I think perhaps that should be X59GL.
The GL suffix suggests that the graphics chip is made by nVidia.
Please try downloading the GeForce for Notebooks driver for your relevant Operating System. You did not mention whether you run Windows XP, Windows Vista, or whether it is 32 bit or 64 bit - you need to know this.
If you check the System Properties in Control Panel, you should find this information.
Here is the driver download page:
http://www.nvidia.com/object/notebook_drivers.html
I hope this solves your issue.
SOURCE: asus f5r audio
Hi there.
You should be able to download and install your drivers from the Asus website here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Product: Notebook
Series: F5 Series
Model: F5R
Then a pop-up window will appear asking for your Operating System, just select WinXP.
4th on the list are the audio downloads. If you click on the + sign, you'll see that there are 3 downloads. Download and install each one in turn.
Hope that helps.
Tim
SOURCE: Audio driver
Go to Asus website.Find product support and/or downloads and put in your model number or serial number and then get only the drivers for XP.If it has a chipset driver among them be sure to install it first in order for all the other drivers to work properly and without problems.
SOURCE: I have asus laptop F5R series i reinstall it now i
driver can be found here. http://support.asus.com/download/download.aspx?SLanguage=en-us
SOURCE: can not install sound card on Asus F5R
alrighty, check your bois see if your audio device is disabled, also check in device manager if theres any multimeda devices that have no drivers, then go to sounds and audio devices in controll panel and select the device and theme for your pc some times Windows has a dedede moments hope this helped ^-^
