Question about Maxon GMRS50 (16 Channels) 2-Way Radio
Progran maxion radio
Our 911 center is adding a repater and will be changine one channel but can not program our maxin hand held radios. do you have a comp. program and cable that will allow us to do this. we have to many radios to ship out to have done
saxis vol fire & rescue
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
How do i program a pro-135 200 channel hand held scanner from radio shack
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps.
Nov 26, 2011 | Radio Shack Radio Communications
How do i reprogram my scanner?
I need help on how to program my radio shack 200 channel hand held scanner sn#C292190?
Feb 03, 2011 | Radio Shack Pro-95 Handheld Scanner
I have a pro 23 hand held scanner it scan but I only pick to weather channel. Thanks, George
You will need to program in your local channels - ANALOG ONLY will work, not Digital. I suggest you go to "Radio Refererence DOT com" and go to their database; select your state, then your county, and it will list many frequencies for you to program to your radio. Also, SOME, not many, but SOME, Radio Shacks actually have a ham radio guy working there that can help you program your radio or help you 'CLONE' it from another identical radio. Good luck, and let me know how it goes. Happy New Year my friend.
Dec 31, 2010 | Radio Shack Pro-95 Handheld Scanner
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
I JUST WANT TO PROGRAN THE SCANNER CODES IN
Press program button, now channel up-down for frequency....You can get them at Radio-freq.com...enjoy....oh, you may have to flip the switch in the back....hope this helps...
Mar 05, 2010 | Uniden Bearcat Pro PC78LTW 40-Channels...
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Need codes to program scanner that is a hand held Uniden Bearcat 30 channel 10 Band Radio Scanner
Frequencies for your area can best be found in databases such as:
www.radioreference.com
or
www.cityfreq.com
Sep 12, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Maxon GMRS50 (16 Channels) 2-Way Radio Logo
46 people viewed this question
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
