Question about Audiovox Water Heaters
Sureflame s400t heaters
Starts up, then shuts off after releasing start button.
  • 2,113 Answers
If it has a pilot light press and hold for 60 seconds then turn the dial to on
Posted on Nov 25, 2013
Ok to turn off water to heater?
yes it is best too in case the heater starts, there is nowhere for expansion.
Feb 12, 2017 | Water Water Heaters
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Bosch 10p, the pilot light went out, when reigniting i pressed the shut off button, now it is locked in and i cant release it, is there a reset button somewhere? regards
Bosch Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
For Bosch tankless troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For Rheem tankless resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 28, 2011 | Bosch & Tankless LP Hot Water Heater
Water heater starts, then shuts down, then starts again, shuts down, etc.
have you tried cleaning out the inline water filter?
sometimes a good flushing will also do the trick. might have some scale buildup inside.
do you have the instruction manual? this will tell you exactly how to do it. if not, I might have one I can copy and send you.
Aug 23, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
My 3 year old "Smart Water" heater will not turn on. No hot water
It sounds like there is air in the line, so open the gas line just a little for a few short seconds to let some gas out, after that, keep the one red dial on pilot then turn the other to about medium. Light the pilot by depressing the red button, then once the pilot is lite, continue to hold the red button for about 1 minute, Once that is done slowly release the button and then turn the dial that is set to pilot to on position and give it about 1 hour to heat up
May 08, 2010 | General Electric GE SmartWater Household...
Burner lights but will not shut off. then pressure
CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
How to check thermstat pop off valve starts
you might want to check the water pressure going into the unit, it should only be no more then 75lbs anything over that will make the top pressure valve blow off
Jun 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Water Heaters Logo
20 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
