Question about Kyocera Fs-3920dn Laser Printer
Machine says to check envelope switches
Switches are set correctly,I switch them, then switch them back and works fine, but keeps doing that intermittenly
My Epson Artisan 835 paper cassette is not set correctly. Details are to follow.
There is a switch that senses when the paper cassette is installed correctly. The switch may have failed in some way that prevents it from closing. You may have to replace the switch to get the machine working again.
Apr 22, 2016 | Epson Artisan 835 Wireless All-in-One...
Duplex printing FS-2100D
in back of machine there is a fuser unit there are 1 or maybe 2 small green buttons or switches on it that is the envelope setting push the button or switch to put it back in normal paper mode
Sep 14, 2017 | Kyocera Office Equipment & Supplies
Cycle not working properly
Hi.
When problem is in the spin part of the cycle it is usually because of either drain filter blockage, siphoning because of incorrect setting of the drain hose at the back, or because of a defective pressure switch.
Check the drain filter, check the setting of the drain hose at the back; clean the rubber hose attached to the pressure switch and eventually replace the pressure switch.
Most washers hide a copy of the service tech sheet inside the control panel assembly, tucked in a sealed envelope. If you retrieve the tech sheet you can also run the diagnostic cycle illustrated in the document.
Regards.
Ginko
Dec 15, 2011 | Washing Machines
My washer has just started to leave about an inch of water in the bottom of the tub after the cycle is complete, leaving my clothes soaking wet. How do I get the water out?
Hi.
The problem is either caused by a drain system fault or by a defective pressure switch.
Check that height and setting of drain hose at the back are correct. If the hose is not set correctly (check manual), then water will flow back inside the appliance. The problem is called siphoning.
Make sure there is no drain system blockage. Inefficient drain because of blockage results in soaked water. Check hose connected to pump located at the base of the washer.
Check and eventually replace the pressure switch. The pressure switch detects water level and determines when to stop the spin part of the cycle. The pressure switch is located in control assembly, near to control module. Clean the long rubber hose connected to the switch.
Inside the control assembly look also for an envelope containing the tech sheet. The document will contain the instructions to run diagnostic cycle in this model. Run a diagnostic cycle.
Regards.
Ginko
Aug 29, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My whirlpool machine keeps sending us the F 6 signal. We have replaced motor, wiring harness, front electrical board (bottom), top back electrical board, water valve. What else could we do? Struts work...
The problem may be with the door lock switch just check whether it is working fine
If it is not working means kindly replace the door lock switch
Jan 20, 2010 | Whirlpool GHW9400 Duet Washer
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
Kyocera Fs-3920dn Laser Printer Logo
29 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
