Question about Nuova Simonelli Musica Lux LED Plumbed Commercial Espresso Machine
Nuova simonelli musica lost all pressure - Nuova Simonelli Musica Lux LED Plumbed Commercial Espresso Machine
SOURCE: Nuova Simonelli Premier
Could be a couple of things. You will know if the pressure is bouncing around by watching your gauges. You want to pull between 9-10 bars when pulling a shot. The programming issue could be the fact that if it is used it could have what I like to call
a touchy brain board. Those do have to replaced every so often depending on how much use the machine gets. You can reprogram whenever shots start pulling bad until you have no choice but to replace the brain board. They are cashy. To program: push the stop and pitcher button at the same time and all lights will start flashing on that head. Have your grind set, use a lined shot glass and measuure your shots according to short or long, watching the flow, crema etc. The ultimate shots pull between 25 and 28 seconds.
Hope this helps.
Posted on Feb 12, 2009
EsWorld
  • 1618 Answers
SOURCE: old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Posted on Feb 26, 2009
  • 10 Answers
SOURCE: putting back nuova microbar
When you say spouts, are you talking about the coffee dispensing nozzles(grey or silver plastic), the piston dispense nozzle(long black plastic) or something else.
Also be interesting to find out what version of machine you have.Version one needed a lot of upgrades, and if these are not present on your machine, then good luck, cos you'll need it.
Posted on Apr 30, 2009
EsWorld
  • 1618 Answers
SOURCE: mac cup V commercial Nuova Simonelli will not ****
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Posted on Nov 18, 2009
EsWorld
  • 1618 Answers
SOURCE: My Nuova Simonelli Mac digit pushes steam out of the group
The metering jet on the top of the boiler is blocked.
Posted on Nov 26, 2009
I have a Nuova Simonelli Aurelia, suddenly the machine lost power? any help
Check the breaker. It might be too much for the circuit with other appliances. If the breaker is OK, pull the plug on the wall and then count to 10 and plug back in.
Jan 29, 2016 | Nuova Simonelli Aurelia Volumetric 2 Group...
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
I'm getting no crema from my Nuova Simonelli Mac 2000 V
Pressure pump is not working or can not produce 9 bar pressure.
Or the coffee is less tha 7 gr.
Or the coffee is grinded too thick.
Please remebr to vote for this answer thanks
Oct 15, 2009 | Nuova Simonelli Mac 2000 I Group Espresso...
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
Sep 25, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Old 1996 nuova simonelli mac digit no pressure or heat
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Nuova Simonelli Musica Lux LED Plumbed Commercial Espresso Machine Logo
164 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
