Question about Coleman 7990-319p Evcon Gas Furnace Control Board
BGU10016A BLINKS CODE 9
I have ck grounding , brakers are power is good, the blower it runs , it starts blinking 9 times. i dont get to hear the exsaust fan nor the igniter come on
    Top Expert:
  • Coleman Master
  • 3,698 Answers
Www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Posted on Aug 03, 2014
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
50 inch panasonic viera blinks 9 times no power
That's a error code but its different for various models. I will need the model number of the set in order to let you know what the 9 blink error indicates for your model Panasonic.
Jan 10, 2013 | Televison & Video
I turn the power on and the green light comes on, ( I hear the click, then the fan, no sound but some snow on the screen) then the t.v. power light blinks red 9 times as it promptly shuts itself off. What...
Service manual indicates the 9 blink code to be a power supply problem, also known as the "g'' board. because of the relative complexity of the TV, I would recommend having a repair shop check the TV and confirm the problem. Good luck !
Oct 03, 2011 | Sony KDS-60A2000 60" HDTV
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
Heater exhaust blower comes on ignitor lights but it doesn't seem to get gas everything works but no flame and blower won't kick on the unit is brand new and was working this morning then stopped
This furnace should have a trobleshooting diagnostic led flashing light. Each blink (for example 3 blinks means open limit switch) has a particlur meaning. On the bottom panel has an explaination on what the blinks mean. But in the meantime check 24v at the gas right as the ignitors light. If you have 24v and the gas valve doesnt let the gas thru then the gas valve might be defective. I usually put 24v dircetly to the gas valve for 2-3 seconds to see if gas will come out. It is loud enogh to hear as well as smell. If you dont have 24v as the ignitor tries to light then check the air pressure switch. Also follow the wire off the gas valve. One is to ground. Make sure the gas valve is grounded. Follow not the grounded wire but the other one. Find out where the 24v power stops.
Mar 24, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Need the code for the charter remote for my vizio
For example, to search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
  3. Enter 9 9 1. The TV key blinks twice.
  4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
  5. Press and release the CH+ key continuously, then stop when the TV turns off.
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
  1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Thanks
Tim
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
Same problem
Press 1 after 9-9-1. The "1" code is the TV code.
Feb 23, 2008 | Jensen JR400 Remote Control
Coleman 7990-319p Evcon Gas Furnace Control Board Logo
187 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
