Question about Baumatic B205SS Stainless Steel Electric Single Oven
Cata Oven EF60SS2 not heating up
Hi there. My oven does not heat up, the light comes on along with fun but there is no heat. any ideas? Also where is the element for this? guessing it is not the same one as the grill?
  • 236 Answers
SOURCE: no heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Posted on Jun 06, 2007
Dinoza
  • 112 Answers
SOURCE: oven fault code
I think your thermostat is broken, try replacing it with a new one.
Posted on Dec 12, 2007
barkencoa
  • 3463 Answers
SOURCE: oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Posted on Nov 20, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
Maytag Oven will not heat up
sounds like the gas valve may not be opening up
Mar 29, 2008 | Ovens
Fan oven comes on but no heat any ideas?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 18, 2011 | Electrolux Ovens
Cata Single Oven Stainless Steel EF60SS Can't get it to heat up
Hi Ya
I have the same oven with the same problem.
To resolve the problem you will need to replace thermal switch, which can be found at the rear of the cooker behind the protective cover. Approx at the bottom left corner. It looks like the shape of an eye with to wires. Hope this helps. Kevin Reseigh
Jan 10, 2010 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
Baumatic B205SS Stainless Steel Electric Single Oven Logo
172 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
