Question about Bosch SHX5AL02UC Dishwasher
My Bosch dishwasher SHX5AL02UC refuses to run a complete cycle . When I order a cycle( push ON /choose cycle/ push START/close door) it is quiet for a few seconds , then sounds like itpumping out wate
I have also noticed that the door latch will "stick" occasionally .This machine is less than 3 years old .
  • Mary nelson
    Mary nelson Nov 27, 2013
    Further info ... the Dishwasher then beeps ,as it does when a cycle is completed . The main brain (memory board ) has just been replaced by the repairman ,trying to solve the problem. Occasionally the door sticks when trying to open it . Help Please ,I will be washing dishes by HAND on Thanksgiving !!!!!
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
  • 409 Answers
SOURCE: Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Posted on Sep 13, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Posted on Aug 05, 2009
SOURCE: my bosch dishwasher door will not latch. It
Same model. Mine acts like it thinks it is closed. It doesn't latch, and the cycle still runs when you open.
Posted on Jun 28, 2010
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Model SHP65T55UC. Why is it beeping?
Hi. I will try to help you.
If what you saying is right, after you hit start. And after some time the dw should indicate a error. I need that error code to be able to help you.
Kind regards
Geir
Technical service enginer @ Bosch Siemens appliances
Feb 15, 2016 | Bosch Dishwashers
How do i operate a basic bosch dishwasher
On many Bosch dishwshers (especially those with the controls on top), they expect your to press the appropriate cycle and option(s) buttons, and then press the Start key, ALL WITH THE DOOR OPEN. Immediately after pressing the START button, close the door (within 3 seconds), and the dishwasher should start.
On other Bosch dishwashers, if you open the door, the poser button is automatically turned off. On those models, you must close the door, turn the Power button ON, and THEN press the appropriate cycle & options buttons. If your dishwasher has a START button, then press it; otherwise just wait 10 second with the door closed.
See? There is no such thing as a "basic bosch dishwasher". Next time, if you have a question, please provide the model number of your dishwasher (or other appliance).
Mar 20, 2015 | Bosch Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHX5AL02UC Dishwasher Logo
42 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
