Question about Cameras
Nikon Coolpix Troubleshooting
I have a coolpix S6300 and it frozen while I was taking a video. I've tried turning it off and then on again. I've tried plugging it in, as well as taking the memory card out and putting it back in, but nothing seems to work.
    Top Expert:
  • Cameras Master
  • 6,702 Answers
The only reason the camera suddenly stops, is when the battery is exhausted. So I suggest you first try to charge the battery. The best way to do that is on the external charger. When you connect the camera to a computer, all things can go wrong during charging, so in the end you still have a battery that has no charge.
Posted on Nov 25, 2013
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 4 Answers
SOURCE: Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
Posted on Jan 12, 2008
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Posted on Dec 26, 2009
caroldon
  • 17129 Answers
SOURCE: I tried to put a
Remove the battery and the camera will shut off. keep the battery off for 12 hours and reinsert back. Remove off the new memory card and switch on with a foramtted memory card.,, maybe the old If the camera resets back to life and functions well then checck if the new memory card has some virrus in the memory, if so scan and delete and format the card.
However if the fault still stays on then you have a fault in the main processor conttroller of the camera which will require extra help.
Hope you take this tip. credit me if this works.
Posted on Aug 21, 2010
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn on¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
Nikon coolpix troubleshooting
I talked to Nikon and thats not suppossed to happen
return it back to Nikon for repair.
Aug 20, 2014 | Nikon Coolpix S6100 Digital Camera
How do I connect my coolpix s6300 to ipad via wifi
The only way I know of is to buy an Eye-Fi storage card and there are some bugs reported with that, but it is reported to work. I have never used one myself.
Jul 02, 2014 | Nikon COOLPIX S630 Digital Camera
My Nikon s6300 won't come on
It is likely the battery is disharged and needs charging. If battery is not charging then it may need replacement or the adapter is not working.
Apr 28, 2014 | Nikon 26302 Coolpix S6300
How to recover accidentally deleted photo on Nikon Coolpix S6300
I also encountered the same problem with my Nikon COOLPIX P100. Fortunately, I found Nikon Photo Recovery software through Google search. It helped me to get back all the lost pictures and video. Read more: http://www.nikon-photo-recovery.com/ Best wishes!
May 21, 2013 | Nikon Coolpix S6300 Hd Video Digital...
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
