Question about Sony Ericsson P1i
Never done an update but phone keeps turning on and off not loading
When turned on during loading it turns back off and on again repeatedly without loading
    New Friend:
This is called a loop virus. Same thing happened to my laptop due to internet use.
Posted on Nov 25, 2013
My samsung galaxy s3 keeps freezing and turning on and off!
your phone is very loaded with the application or your phone is going to hang so you have to update your phone or go to the the service center to resolve this problem
May 19, 2017 | Cell Phones
When i chage it it turns on and turns back off and it will keep repeating that so i cant use it
its a software problem . the phone needs to get a fresh software update. after the software update everything will work fine.
Feb 18, 2012 | HTC FUZE Smartphone
Phone shut of and keeps repeating the load screen but wont turn on
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Dec 09, 2010 | Samsung Cell Phones
Samsung ace won't turn on
Usually that happens when the firmware update failed. Try to connect your phone again to your PC then try to update again.
May 27, 2009 | Samsung Ace SPH-I325 Car Charger
Autoamatically loading loudspeaker option and multimedia utility.
I think your phone may need a Software/Firmware update. Before doing that, try resetting the phone:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Then update the Software (sometimes called Firmware) thus:
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 27, 2008 | Nokia N70 Cellular Phone
Is it really dying?
It's possible the battery is dead, but the phone may also be too full of old files/msgs/pics/applications/games etc... the phone needs a certain amount of memory to function.
Try another battery or a new one, if it starts do an update of the phone software (firmware). You can do this yourself, but it may be better left to a repair/sales shop.
You need to download the latest Samsung PC Studio to do an update on your phone.
WARNING
“I can resist anything but temptation.”
Apr 25, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Stuck on nokia start up screen
Try this:
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
WARNING
And obviously don't unplug the phone from the PC.
If the PC freezes during an update, you're up the creek without a paddle...
Mar 25, 2008 | Nokia N70 Cellular Phone
Sony Ericsson W910i turning off
This happens when u have half updated software. Best solution is to update ur phone software.
1) Go to www.sonyericcson.com/support
2) Or go to settings in W910i in general tab go to update service where u can see ur current software and also u can update it via air(but keep in mind of the charges).
3) U can also update it from ur nearest sony ericcson service centre.
Mar 19, 2008 | Cell Phones
Wide screen
----------- Don't format your mobile phones -----------
----------- Don't update software on mobile phones unless there's a newer version -----------
WARNING
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
Dec 29, 2007 | Nokia N70 Cellular Phone
Sony Ericsson P1i Logo
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
