Question about New Home Sewing Machines
Can't change stitch select
The stitch is stuck on triple stitch I can't get it to regular stitch. moving dials won't help
Zenqi
  • 208 Answers
SOURCE: Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Posted on Feb 21, 2010
  • 68 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
  • 1788 Answers
SOURCE: Buttonholer operation
push the lever back, look at your manual and you will see what I mean. Read the manual and watch the dvd and you will see what you are doing wrong.
Posted on Aug 30, 2010
SOURCE: I have an old kenmore
make sure stitch length is in proper color area
Posted on Dec 02, 2010
  • 1456 Answers
SOURCE: I have a Viking 6370 sewing machine. I can not
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Posted on Jul 12, 2011
Testimonial: "That was the problem exactly. I am going to order a new cam gear and replace it. Thanks"
My machine is doing a triple stitch and I don't know how to make it stop!
Best course would be to consult the owner's manual. It has most likely been inadvertently set to triple stitch--may even be a combination of stitch dials..
Feb 22, 2016 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Needle alignment
it's possible that the needle bar is out of adjustment or bent
I would suggest to have the machine checked by a service
technican
Nov 22, 2012 | Sewing Machines
Pattern selection dial
take the machine back & get another one
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
Setting stitch length
Get some scrap fabric. One dial is for the width of the zig zag stitch, the other dial is for the length of any stitch. First set both to ZERO. It won't move then set one to half way. This will show you which dial is which. If it is the width dial. You'll get a bar tack. If it is the length dial you'll get straight stitches.
Aug 01, 2012 | Sewing Machines
The stitch length adjustment will not switch the length
since the dial won't move, the machine needs to be checked
May 19, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
I have an older New Home Sewing machine XR-V11 electronic I have figured out the threading, bobbin, regular stitching and back stitching. It has alot of fancy stitching on it I can get the dial to move to...
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Mar 06, 2010 | New Home HF-2022
Sewing Machines Logo
21 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
