Question about Kyocera FS Office Equipment & Supplies
Kyocera fs-4020dn; Error code 6000
My Kyocera Ecosys FS-4020DN printer gave the 'call for service' with the 6000 error code. I read the description of the problem, it sounds as is decribed, that the issue is with the Fuser itself. I replaced the fuser, still the error code remains. I also checked the connector for continuity from the front of the connector to where the wires seem to end and all was good. What to check next?!? Is the PWB defective? how can I check?
  • james macdonald
    james macdonald Nov 26, 2013
    I have turned off, unplugged, left it over night. Nothing. If it was the fuse inside the Fuser unit, wouldnt replacing the Fuser have solved the issue?
Where is the fuser themistor located.. if the replace the new fuser from maintenance kit, is the termistor been replaced as well?
thanks
Posted on Jan 09, 2014
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Be sure to power down and disconnect the power first.
A fuse it is blown within the fuser unit - replace that fuse or call a technician to do it for you.
Posted on Nov 25, 2013
Testimonial: "I have turned off, unplugged, left it over night. Nothing. If it was the fuse inside the Fuser unit, wouldnt replacing the Fuser have solved the issue?"
  • james macdonald
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
SOURCE: kyocera fs-3820 no power
You don't have to replace the fuser. You can fix it by taking the fuser apart & repairing the thermostat. This is located under the fuser roller. Take the thermostat apart & bend the metal plate on top just a little, then put everything back together. This works prefectly & will save you money. The heat from the roller makes the metal on the thermostat bend & releases the contact on the inside.
Posted on Sep 03, 2009
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
What causes the printing to be cut off around the page edges on my Kyocera FS 4020DN?
when we want to print from email then
there is a print button within email if self probably right side of email which one is opened
a small print symbol is there try with these button
it opens a new widows from which good print can done
Aug 19, 2014 | Kyocera 1102J22US0 Model FS-4020DN Laser...
7410 error code
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmly on the drum which is located behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
Aug 02, 2013 | Kyocera 1102J22US0 Model FS-4020DN Laser...
FS4020DN cod 0150:0016981 ?
sounds like the drum been taken out and not pushed back all the way.Open the left door and push the drum unit back in
Aug 15, 2012 | Kyocera fs 4020dn laser printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
Hi thats aproblem in my printer
this call service belongs to
The main motor is overloaded
1. please check the main motor rotaing smoothly
2. Defective harness between engine board and engine relay board and main motor
Jun 10, 2009 | Kyocera Mita FS 1900 Laser Printer
462 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
