Question about Bodum Antigua 5670/5671 Electric Burr Grinder
Bodum antigua fuse
How to replace fuse?
My bodum burr grinder stopped while grinding beans. It will not run at all.
If all the above except some lame answer about using "rice" doesn't solve your problem, then the THERMAL FUSE will have to be replaced, and it is very easy and cheap to do so, especially if you do it yourself. A THERMAL FUSE will shut down everything so that if for any reason the machine overheats, it won't burn up the motor.
Sep 29, 2014 | Bodum Coffee Makers & Espresso Machines
Where can I find a replacement
https://www.baratza.com/cgi-bin/commerce.cgi?listcategories=action&parent=PART
Jun 12, 2014 | Bodum Antigua 5670/5671 Electric Burr...
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
Jan 13, 2014 | Bodum Antigua 5670/5671 Electric Burr...
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Feb 21, 2009 | Bodum Granos 3020-16 Espresso Machine
Bean Bowl Sheared off
try www.smallappliance.com They've got all kinds of stuff. If the online doesn't have it, call them. Other suppliers? Here's a bigger list: http://www.jneuhaus.com/appliance/index.htm
Nov 27, 2007 | Bodum Antigua 5670/5671 Electric Burr...
Bodum Antigua 5670/5671 Electric Burr Grinder Logo
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
ray gallant
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
