Duplicator riso graph cz180 error code h401 solution
  • 65 Answers
SOURCE: Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Posted on Dec 02, 2008
  • 81 Answers
SOURCE: Riso GR 375 How to change language
turn machine on .. then press the "8" and the " * " at the same time to enter user mode...
user mode 17 changes language
Posted on Jul 07, 2009
  • 17 Answers
SOURCE: error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Posted on Mar 30, 2010
SOURCE: Ks 800 Riso Digital duplicator Machine my Machine
que significa el codigo de error e13 el riso ks 800 y que devo hacer para slolucionar el problema
Posted on Feb 09, 2011
sodeep
  • 3267 Answers
SOURCE: I have an error code H401 on my sharp AR336
H 401 means Heat roller low temperature detection. i.e. The temperature does not reach the
preset value within the specified time (3 min. in usual modes; 5 min. in curl correction mode.) after the power relay is turned on.
Possible causes
Thermister defective
Heater lamp defective
Control PWB defective
Thermostat defective
AC power supply defective
Interlock switch defective
Possible remedies
Check heater lamp for blinking with SIM5-2.
If lamp blinks properly:
Check thermister and its harness. Check thermister input circuit of control PWB.
If lamp does not light:
Check heater lamp for broken wire and thermostat for operation. Check interlock switch.
Check lamp control circuit of AC PWB and control PWB.
Clear the trouble with SIM14.
Posted on Jun 13, 2011
Error h401 on my duplicator
if you are using a colored drum, you need to change the value.. if black, just press green or start button then you are good to go. hope to be of help.
Feb 12, 2014 | Riso RZ220 Duplicator
Why is my riso EZ20 blinking H401
h401 is not an error.. it needs to confirm if the original to be scanned is colored or gray scale... first it will go to H101.. just press start, then H401 press start.. you can start doing your jobs. hope to be of help.
Feb 12, 2014 | Riso Office Equipment & Supplies
Error code J04 for riso cz180
riso cz -180 mechine
problem :- code eror :- P02-400
Mar 02, 2013 | Office Equipment & Supplies
Riso EZ 570 e "T12-301" error. What is this error
check master disposal box. take it out and check for jams
Nov 01, 2011 | Riso RZ220 Duplicator
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
Ks 800 Riso Digital duplicator Machine my Machine problem is E 3 code (sir plz Answar )
Feb 04, 2011 | Riso RZ390 Duplicator
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Code Error T4
Dec 01, 2008 | Riso RZ220 Duplicator
148 people viewed this question
jasbo
jasbo
