Question about HP Compaq Sound Card
Dc7100 realtek Not is open volume control and not is work sound ,,fast is my pc goo but after 2 days is not proprley work ...
How downlod lan driver
Posted on Nov 25, 2013
Why doesn't my internal "realtek" sound system have any sound?
Check that the speaker cable is plugged into the GREEN ringed "Speaker" jack (for a normal stereo sound set up). Check that the speaker isn't muted in system tray. Right click the speaker in the system tray. Click Volume Control Options and make sure you have the analog Realtek Audio selected - not any HDMI or Digital output. Open "Control Panel" in Windows. Open "Device Manager" found in the "Hardware and Sound" heading. Locate "Sound, Video.." Make sure there is no small icon over it to indicate that there is a problem. If there is, click the triangle to the left and open "Realtek.." Right click it and select properties. Click the Driver tab and then "Uninstall" If an option to remove files is presented - select it, too. Click OK to uninstall. Reboot if prompted. Allow Windows to find the "new" Realtek hardware and download drivers from Live Update. Sound should be restored. Make sure that you have selected Analog
Apr 14, 2015 | Acer Veriton X275 PC Desktop
917-Front Audio Not Connected hp compaq dc7600
click start control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers
hope it helps
Nov 25, 2011 | HP Compaq dc7100 PC Desktop
No audio, no ethernet
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
May 19, 2011 | Intel 865G Motherboard
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
Apr 01, 2011 | Computers & Internet
My headphone's mic is not working in my pc while it is working in others pc.My headphone's model is:Odyssey OD 212.My sound driver is of realtek.I am using Windows xp service pack 2.
Possibly Your MIC is muted in Volume controller -Advanced increase the volume of the mic. Check the proper mic is selected using advanced audio properties
Mar 25, 2011 | Computers & Internet
Audio driver is working properly but mic is not working.....using lenovo g430 3000
If the audio driver is working properly but the microphone isn't, ensure that: 1(a). The microphone is not muted.On Windows XP, go to start, run and type sndvol32 and press enter button to launch the Windows Sound Volume Management Panel. Under the Microphone volume control, uncheck "mute" box.This should make your microphone functional again. (b). The wrong microphone may be selected, esp. if your sound-card has an external port for microphones.To rectify the problem, use 1(a) as illustrated above, go to File>Advanced Controls and select Input Devices.Under the Microphone advanced settings, you'll see MIC1 Select and MIC2 Select. Switch the selection as appropriate until it works. 2. If the audio driver has it's own Sound management Panel, e.g that of Realtek, open it's sound control panel and disable all microphone effects that may be enabled. 3. Ensure that sound acceleration is maximum. Open the DirectX Diagnostics Engine by going to Start>Run> and type dxdiag and press enter button.When the window opens, click the Sound tab and slide the Sound acceleration bar to maximum.
I hope my solutions work.Have a good day.
Feb 11, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I'm running windows xp/sp2 on Acer Aspire 3000 laptop. I've had sound working just fine ever since I got this machine, but just sometime in the past two weeks it has quit on me. When I open the volume...
first of all change the play back set from head phone in the audio tab and see if there is mute option on on the speakers symbol on the system tray bottom right hand on the system if yes uncheck the mute
Oct 26, 2010 | Acer Aspire 3000 Notebook
Volume on computer wont work
I found many references to this issue but I am not sure which may apply to your problem. Here is a set of steps to follow from another site: (Assumes Vista and Realtek)
  • Open Vista’s Control Panel (Window | Control Panel)
  • Open the Realtek Audio Manager (not “Sound”)
  • In the navigation bar in the far right, there is a little yellow folder icon. It is just below “Device advanced settings” and above “ANALOG”. Click the folder icon.
  • Click “Disable front panel jack detection” so that a yellow check mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That should re-enable the sound.
Mar 14, 2009 | Microsoft Windows Vista Home Basic for PC
Realtek RTL8201BL Fast Ethernet controller
http://rapidlibrary.com/index.php?q=realtek+rtl8201bl+sound+drivers
they would be here
Jan 26, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
