Question about Dryers
I have an optimus stav 3670 stereo reciever that wont turn on. I have located 3 fuses, all test good. No lights, click, or any sound or reaction when power button pushed. I'm hoping there is a 4th fuse that I can't locate. Continuity from plug end all the way to transformer. Any ideas, I hope. Thank you, Mike.
    Problem Solver:
  • 16 Answers
Mike, sounds as if it's not getting voltage to the remote control receiver circuit? Meaning that there is a low voltage (5volts) that sits there and waits for the signal from your remote to turn the unit on. This is also through the front power switch which is also tied to your on-off power relay. I would check for 5 volts around that. More that likely you a 5 volt regulator shot. Hope this may help?
Posted on Nov 26, 2013
Buffalo12980
  • 625 Answers
SOURCE: Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Posted on Sep 22, 2007
SOURCE: dryer power
your motor is fried
Posted on Dec 01, 2007
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
  • 2330 Answers
SOURCE: Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Posted on Nov 06, 2009
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
I have an optimus stav 3670 that won't turn on. I have located 3 fuse which all test good. No lights or sound when power button pushed. Continuity from plug end all the way to transformer. I'm hoping there...
Is your receiver plugged directly into a wall outlet; use your voltmeter (or in absence of one, a desk lamp or some other small appliance) into each of the duplex receptacles. I have gone on service calls where the outlet was defective- where one side of the duplex receptacle had power to it, while the lower branch was dead.
Or is your receiver plugged into a power strip / surge protector?
Check to make sure that the internal breaker (if so equipped) did not "trip". I would also check each of the outlets on the strip to make sure they have power going to them too. One could be out while the rest are fine.
The reason why I say this, is you mentioned you have continuity (the potential path for electricity to complete its circuit) but you did not mention if you are getting voltage (energized) from the plug to the transformer.
Check voltage readings at the power "on-off button too- remember, a switch is just a break in the line current. That may be defective.
Nov 25, 2013 | Televison & Video
How do I set up the surround sounds to my T.V. using the optimus 3770 audio reciever?
Does your TV HAVE surround sound? THAT would be different.
Some simple text intructions for thge receiver...
http://support.radioshack.com/support_audio/47464.htm
Feb 04, 2011 | Optimus STAV-3770 Receiver
When I turn on the STAV-3770, after the five seconds for the inital click that is ready to go, the unit turns off and back on and keeps repeating this process.
Most of these units come with a replaceable fuse in the back (about the diameter of a penny). I believe that the unit will shut itself off if the fuse is blown. Excessive use, moisture or a power surge will blow the fuse. Radio shack may have a replacement for you to buy. I would try this first, as it is a fairly inexpensive solution. If it turns out that you have a more serious electrical problem with the unit, I would consider replacing it. The new 5.1 systems are cheaper than ever, more energy efficient and sound better to boot.
Sep 26, 2010 | Optimus STAV-3770 Receiver
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Sep 07, 2010 | Optimus STAV-3770 Receiver
Reciever connection problem
I am having problems connecting my Advent AW 10 wireless speakers up to my STAV 3770 reciever. What jacks to I connect to with my RCA cable to make a connection?
Dec 22, 2007 | Optimus STAV-3770 Receiver
Dryers Logo
Top Dryers Experts
