Question about Panasonic ES 8077S Electric Shaver
Panasonic ES8249S won't clean - Panasonic ES 8077S Electric Shaver
Cd player won'start
try cleaning the optics with a soft cloth or Q-tip and isopropyl alcohol(just a drop!!!!) start it again....otherwise replace pickup..... regards, meder's tv service
Aug 15, 2012 | Panasonic RX-D11 Cassette/CD Boombox
My Panasonic SAPT480 won't play dvd+
You can buy a DVD cleaning kit and follow instructions, or get a Q-Tip and rubbing alcohol, gently clean the lens and allow several minutes to dry before testing, if this fails the whole laser pickup assembly will need to be replaced, cheaper to buy a new player.
Jun 06, 2012 | Panasonic new 8.5-inch portable dvd player...
Panasonic DVD player dvd cv37 won't play discs.
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer play the disc. Buy a DVD cleaning kit and follow instructions, this may give more life to the player, if no change! it is far cheaper to replace than to repair.
Mar 20, 2012 | Panasonic Televison & Video
NO READ CHECK DISK ON UNIT. RESET HAS NOT WORKED
try a DVD cleaning kit and follow instructions, if that won't work! clean lens with a Q-Tip and rubbing alcohol genly, and allow several minutes to dry, if no result it is cheaper to replace the player than replacing the laser pickup assembly.
Mar 19, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic ES-LV81 electric razor with self cleaning recharger won't go into clean cycle only dry.
If you take the cleaning unit to pieces you will find a tiny microswitch that detects that the cleaning cartridge is in situ. This switch is fed by 2 brown wires. The microswitch is prone to get water on it and then malfunctions. Unless you are adept enough to find a new one and fit it, in my opinion the only way around this problem is to snip one of the brown wires and re-assemble the unit.
Effectively this is overriding the units ability to sense that the cleaning cartridge is in position!
As long as you remember to NEVER run the unit without the cartridge in situ, the wash and dry cycle should work fine.
Best Regards.
Ian.
Feb 04, 2012 | Panasonic ESLA93k Electric Shaver
Won't read disc
try to clean the eye lens with dry cotton or tissue. if not, the motor or dynamo is defective.
Feb 03, 2012 | Panasonic DVD-RP56 DVD Player
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
COPIER SHOWS ERROR CODE E03-85 AND WON'T CONTINUE
Your non op color registration sensor is probably dirty. You need to remove the transfer belt and move the sliding plate to expose the sensors to clean them.
Jun 06, 2011 | Panasonic DP-C264 Color Copier
It won;t come on
Check and clean the connectors that seat between the C boards. C10/C20 is the likely one to cause it.
Jan 14, 2011 | Panasonic TC50PS14 Plasma TV
Panasonic ES 8077S Electric Shaver Logo
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
